Question about GE Refrigerators
I have a sheet of ice in the bottom of freezer compartment and frost. any suggestions
The ice maker works fine. there is frost accumulating and once the bottom gets to full with ice it starts to spill out the front. the temperature is usually right around 0 degrees
  • GE Master
  • 4,654 Answers
You either have a defective water control valve that allows water to seep into ice maker while the water control valve is off or your defrost drain found behind the rear panel in the back of your freezer.has become clogged. Click Here=> Leaking Refrigerators Just What may Be Happening If the dual water control walve is causing this the only way to fix the problem is to replace the water control valve. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Posted on Feb 13, 2012
catriver
  • 878 Answers
SOURCE: Frost on Ice Maker shute
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. Catriver..post back.
Posted on Oct 21, 2006
fridgetech
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
  • 139 Answers
SOURCE: Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Posted on Jan 11, 2008
  • 21 Answers
SOURCE: Freezer quits working
Good Day, I live out in Ca. and have only experience temp's like what you guys endure once in my lifetime. But I grew up, with Bart Starr, he was my guy, leading the Pac. in the Ice Bowl. I'm hoping to get one of the guys to add to my comments I'm going to suggest to you, there are many guys more qualified with more experience than I, that might offer more. Sometimes with Refrigerators and Freezers, is that during periods of long cold spells, the appliances can actually NOT produce enough Run-time to sustain the foods inside. In other words, because its so damn cold it will go off and if the thermostat doesn't sense the temp has risen to the point it needs to come back on, it won't. Ice creams, because of the salt content, bread (it has no density) these will be the first foods to be effected. 20yrs ago I remember we have a strip heater... wr49x211 I think it was, to add heat to get the thermostat to cycle back on.... Check around, ask -Re-post and List it.. I want somebody who knows Refer's, Lives and Works in tough weather... that'll get an answer
Posted on Feb 27, 2008
My Kenmore Model No 596.69282012 bottom freezer fridge develops a thin sheet of ice on the bottom of the freezer compartment. I have checked the freezer seal and it is intact. Any suggestions?
Is it supposed to be a frost free freezer?
I had one to act like that, but it was on warranty and they repaired it for me.
I wish I could have been able to help.
May 15, 2017 | Kenmore Refrigerators
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Excessive frost buildup in bottom freezer section of Kenmore refr
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. if this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that can occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of your ice maker causing this are very, very slim...in 35 years in the industry ..I have never had an ice maker cause frost due to water spray...it will almost always result solid sheets of Ice..if it evers does cause a spray....which like I said is rare...lottery ticket type rare :-)
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Mar 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
