Question about Canon PIXMA MP530 All-In-One InkJet Printer
Too much magenta
My photos are printing with too much magenta. I just replaced that cartridge. Also ran a cleaning which helped slightly.
I had this problem which appeared to occur after a blizzard of protests because of using generic cartridges (reuse chip from old Canon cartidge).
After several months of not being able to print, I found a firmware download (v1.08) and it has been printing normally since (1 day).
Posted on Oct 26, 2008
My canon pixma 210
You will need to use your printers maintenance setting to clean the heads. Find your printer in Control Panel/Printers then right click on it and select properties. Select the maintenance tab and then select clean print head. You may need to do this a few times
May 29, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Everything prints pink! Head cleaning help on test page but next print was pink again.
I have a Canon S9000 and when this happened to me it was because the magenta or photo magenta cartridge leaked and spread. I had just refilled the cartridge and the plug didn't have a tight enough seal.
I took out the cartridges and used a Q-tip, OK, a TON of Q-tips, with the cleaner fluid from the refill kit on them and cleaned out the bottom of the holders where each cartridge fits.
I also had to do this to the ink ports of the cartridges themselves because they were tainted as well. I ran the head cleaning program a couple of times and once it was as good as it was going to get, I repeated the cleaning of the holders again, bought all new cartridges and ran the head cleaning program again until the problem was gone.
Jul 29, 2009 | Canon S900 InkJet Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Prints magenta line slightly off center on everything
Try a printer calibration.
If this doesn't work than comment again. I have one of these printers at work and I can do more to help tomorrow.
Oct 16, 2007 | HP Color LaserJet 2600n Printer
Changed ink cartridge, now printing with green hue
check the magenta cartridge is it not dry or try to clean the magenta cartridge nozzle and see. bye
Sep 24, 2007 | Canon I960 InkJet Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
108 people viewed this question
old marine
old marine
