Question about Samsung R519-53S Notebook
Samsung R519 shuts down unexpectadly - Samsung R519-53S Notebook
  • Samsung Master
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Posted on Feb 12, 2012
  • Samsung Master
  • 5,660 Answers
Suspect Samsung R519 is dirty inside.
http://www.cnet.com.au/samsung-r519-339300512.htm
The cooling system for the Samsung R519 is the Cooling Tube, Heatsink, and Fan Assembly.
The Fan Assembly consists of a Fan, and surrounding cage. (Shroud)
The Heatsink is a thin piece of metal, that has Tall, Thin, fins protruding from it.
The fan's blades, center hub, and surrounding cage may become clogged with 'Gunk'
{'Gunk' = Dirt, dust, hair, food crumbs, lint, etc}
The fins of the Heatsink may become clogged. In-between the fins, and all over the fins.
{ The Heatsink absorbs heat. It then radiates the heat way through the Tall, Thin, fins }
When a Processor overheats, (Surpasses it's Thermal Limit), it turns off.
(BIOS turns it off)
This is a fail safe feature built in. Keeps the Processor from burning up.
With the cooling system being clogged, the Processor overheats.
Solution is to clean the laptop THOROUGHLY. I don't believe at this time a can of compressed air for computers, blo-wing air from the outside, will help.
It will just push the 'Gunk' in tighter.
The laptop needs to be disassembled, and thoroughly cleaned out.
It may, or may not need new Thermal Paste for the Processor, and graphics chipset.
(If the laptop has been cleaned recently, and has this problem, it's because the 'tech' probably didn't replace the Thermal Paste.
Thermal Paste will dry up over time, and lose it's thermal conductivity properties )
Do you wish to attempt this cleaning procedure yourself?
If so post back in a Comment, and prepare for a LOT of reading.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-samsung
(The R520 is VERY similar )
http://forum.notebookreview.com/samsung/117192-samsung-x20-cleaning-cooler-fan.html
The above is for a Samsung X20. Posted, because I would like you to look at the last photo on the page. Here you see an average finned Heatsink, and the 'Gunk' it can collect.
Regards,
joecoolvette
Samsung r519 laptop
Try checking for updated drivers.
Mar 24, 2014 | Computers & Internet
How to do a system restore
Have you rebooted the Laptop? shut down, unplug, remove battery, plug in, reboot, the device should install the device. Open Device Manager, look for Network Adapters, open Is the wireless device there? Post results. If no right click network adapters and Scan for Hardware changes. You can find the Wireless Adapter driver here, select the correct OS: http://www.samsung.com/uk/support/model/NP-R519-FA06UK-downloads
Mar 01, 2013 | Samsung R519-53S Notebook
How to replace speakers samsung r519
I think you should use youtube, it really helps
Jan 25, 2013 | Samsung R519-53S Notebook
How to turn on mouse wake up
Open Power settings, Choose High Performance, Change Sleep to never, Hibernate to Never, Shut down computer when not in use.
Dec 20, 2012 | Samsung R519-53S Notebook
Factory reset samsung r519 laptop
RTM - Read The Manual.
Your manual says if you can boot into windows then click Start/All Programs/Samsung/Samsung Recovery Solution
If you cannot boot into windows when you turn the computer on hit the F4 key.
The link below will take you directly to your manual
http://www.samsung.com/us/support/owners/product/NP-R519-FA01US
May 01, 2012 | Samsung R519-53S Notebook
Samsung R519-53S Wireless Driver
were can i dowload wireless drive for samsung r519 anyone
Jan 27, 2012 | Samsung R519-53S Notebook
How do i replace a sammsung R519 keyboard?
Step one: Remove the two screws from the bottom of the computer that are holding down the Samsung R519 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Samsung R519 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Samsung laptop keyboard.
Final step: To insert the new Samsung R519 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Samsung R519 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Apr 01, 2010 | Samsung NC10-14ROBL Notebook
FITTING INSTRUCTIONS FOR FITTING A SAMSUNG R519
very simple the keyboard clips of if you get a sharp instrument such as a knife put it down the side of the keyboard and wedge it in then push down and it will clip off.
Mar 31, 2010 | Computers & Internet
Cant find a wireless function on my samsung r519 please help
Press and hold [Fn] key - while you tap the [F9] key That turns WiFi On/Off on Samsung NP-R519
Mar 04, 2010 | Computers & Internet
Samsung R519-53S Notebook Logo
1,147 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
