Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
My pto want work on my troy bilt 50' zero turn
When I pull the pto switch nothing happens the blades want engage.I replaced the pto switch but still nothing.I changed the battery still nothing.I checked the pto clutch and it does click.Does anyone have and idea what I might need to check next?
  • 430 Answers
  • 5 Answers
SOURCE: PTO clutch will not engage.
first start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. if not use a twelve volt test light,hook aligator end to a good groundand the needle end,,,touch to the pto switchharness to see if you have power to the pto switch. if you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. you can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It willengage if it is good .using either wire is ok as all it will be doing is completing a circuit. hope this helps.
Posted on Sep 24, 2009
  • 138 Answers
SOURCE: When I engage the PTO, the blades don't egage.
The first thing we need to to do is verify that there is adequate /(power 12 vdc) going to the electric clutch, you can do this by unplugging the clutch and check both wires 1 should have 12 volts and the other wire shoud read infinity to ground if this checks out replace the clutch, if you dont have 12vdc to the wire replace the relay
Posted on Sep 07, 2009
  • 376 Answers
SOURCE: Toro mower is blowing 30 amp fuse
Yes it is. It is an electro-magnetic device that 'grabs' your blade pulley, that normally free wheels, to turn your blades when there's power to it. Dwain
Posted on May 24, 2009
  • 73 Answers
SOURCE: pto clutch
check tension on belts
Posted on Oct 02, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
Blades won't engage on John Deere x540.
I would remove the PTO switch and have a Deere dealer test it. Also on the 500 series the PTO operates through the ignition control module which is under the dash, you can see it when you raise the hood. It is black and about 2" wide x 3" long and 1" thick.
Jul 29, 2017 | John Deere Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
I have a cub cadet rzt50 2006model, when I pull the PTO switch to engage the PTO nothing happens
check to see if you have voltage to pto if do bad pto replace it if not check the fuse then the switch
Aug 26, 2014 | Garden
Husqvarna riding mower
Jim, I believe your tractor has an electronic knob for engagement (if I'm right in you having a matching post about a husqvarna with a knob for engagement. And it also has a PTO clutch off the motor. Having a little slack in the belt is not bad if it's not so much that it doesn't grab at at all. Does anything happen at all when you pull the switch? If nothing happens at all, the switch could be bad, the PTO clutch could need adjustment or be bad, OR you may simply have a very weak battery that isn't supplying enough current to engage the PTO properly under loads. Sometimes the batteries and charging units in riding mowers are very borderline in being able to handle the loads and a weak battery can cause unsuspected problems.
Aug 10, 2013 | Garden
Belt. came off... pulling up blade engagement knob nothing seems to happen.....I have trackter up on blocks with blade cutting height at 1 with engine runnig the blade engagement knob switch ...
sounds like a bad PTO, that is the electrical gizmo on the bottom of the engine's driveshaft which engages the bottom pulley, running the deck. you might luck out and find the fuse is blown so follow the wire from the PTO back until you find the fat part in the wire. the fat part is an in line fuse holder with a fuse in it. if the fuse is bad and blows again, you need a new PTO
Aug 19, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
My PTO switch does nothing - blades do not engage - how do I fix? I pull up the switch and nothing happens. Model is YTH2448T serial # is 279200, I think it is a 2006 model. Help - please.
With test light check for power at the switch and at the plug of the pto. There might also be a fuse blown. You can always check the pto by jumping power from the battery to the pto with engine off and you can hear it click and see it move to verify that pto is not the problem.
Mar 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Jul 16, 2009 | Husqvarna Garden
My Cub Cadet 2135 PTO won't engage.
these mowers are riddled with safety switches. i would lean toward one of them malfunctioning. is the battery charged up? a weak battery will not engage the electro magnet.
May 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
2,418 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
