Question about Xerox Phaser 6130 Laser Printer
Reset imaging unit phaser 6140 - Xerox Phaser 6130 Laser Printer
  • 22 Answers
SOURCE: Is it possible to reset xerox phaser 6110mfp
The image unit can be reset.
This is done by use of a small program that Xerox certified engineers use. The process is really simple and only takes about 30 secs, if you have access to the program ( I do... :) ) It can also be used to reset transfer belt life etc ....
Posted on Mar 07, 2010
  • 340 Answers
SOURCE: Dear support hi! I need
Solution : Replace the Imaging Unit The life of the Imaging Unit is approximately 20,000 pages for black and white, or 12,500 pages for color. When the life span of the Imaging Unit has expired, the Smart Panel program window will be displayed on the computer, indicating the unit needs to be replaced; otherwise, your printer will stop printing.
WARNING: Some parts inside the printer may be hot when the printer is powered ON, or after printing. Be careful not to burn yourself when working inside the printer.
To replace the Imaging Unit:
  1. Power OFF the printer. Press the power switch on the back of the printer to the OFF position (O).
  2. Wait for the printer to cool.
  3. Open the Front Cover.
  4. Remove all of the Toner (Dry Ink) Cartridges and the Waste Toner Container from the printer. See the Related Items below for additional information.
  5. Pull the Imaging Unit out of the printer using the handle on the bottom of the unit.
  6. Extend the top handle on the Imaging Unit and then grasp the handle to pull the unit completely out of the printer.
    CAUTION: Do not use sharp objects, such as a knife or scissors, to open the Imaging Unit package as this could damage the surface of the unit. Be careful not to scratch the surface of the unit.
    Do not expose the Imaging Unit to light for more than a few minutes. Cover it with a piece of paper to protect it, if necessary.
  7. Remove the new Imaging Unit from its package. Remove the protective devices on both sides of the unit and the paper protecting the surface of the unit.
  8. Holding the handles on the new Imaging Unit, insert and push the unit into the printer until it clicks into position.
  9. Remove the four dummy caps on the Toner Cartridge entrances of the Imaging Unit.
  10. Re-install the Toner Cartridges and the Waste Toner Container into their corresponding slots until they click into position.
  11. Close the Front Cover and make sure it is securely latched. If the cover is not completely closed, the printer will not operate.
  12. Power ON the printer. Press the power switch to the ON position (').
    NOTE: Each LED on the Control Panel blinks red in a repeated order. Wait for about three minutes for the printer to reach a 'Ready' status.
    NOTE: If there is a cracking sound, re-install the Imaging Unit.
Click on the [Recycling] link under the Product Resources menu on this window.
Posted on Oct 30, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
  • 304 Answers
SOURCE: How to reset Phaser 6110 imaging unit.
No reset for imaging unit, only when you change it(autoreset).
You can reset Fuser and Transfer Roller this way:
To reset the fuser and transfer roller life usage from the printers control panel:
a. From the main menu select, Menu-Setup --> Maintenance --> Check other.
b. Select the appropriate part name from the list by using the Up Scroll and Down Scroll buttons
c. Select Reset.
Posted on Jul 11, 2011
StevenC82
  • 160 Answers
SOURCE: can i reset the imaging
There is a chip in the bottom of the image unit which stores the image unit life. These can be reset but it requires special hardware and software to do it. You can also buy replacement chips, they're usually about $50 for a 4 pack and you can find them on e-bay. Rechipping with out replacing the entire image unit will result in lower quality prints though.
Posted on Aug 12, 2011
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Phaser 6505 imaging unit life reset
HELP.. replace transfer unit... I replaced it.. still a
replace transfer unit message.. help!!
Nov 27, 2013 | Xerox Phaser 6128MFP AllInOne Laser...
Reseting a printing module
No you have to replace it otherwise you get bad quality
Jun 19, 2013 | Xerox Phaser 4500 Printer
Program to reset unit imaging xerox phaser 6110 please
Image units can't be reset by software. There is a chip that needs to be replaced on the cartridge if you refill it with new toner. It should be available from the same place you got the toner. (I assume you refilled it and it still says it is out of toner)
Dec 01, 2011 | Xerox Phaser 6110 Laser Printer
Can i reset the imaging unit on my phaser 7750
Aug 09, 2011 | Xerox Phaser 7750DN Laser Printer
c. Select Reset.
May 18, 2011 | Xerox Phaser 6110 Laser Printer
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Is it possible to reset xerox phaser 6110mfp imaging units
Mar 02, 2010 | Xerox Phaser 6110 Laser Printer
Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Jul 24, 2009 | Office Equipment & Supplies
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 6130 Laser Printer Logo
994 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
