Question about Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP
Power trim stopped working on my 1988 150 hp evinrude outboard
Trim stopped working. Is there a fuse or reset breaker for this system?
  • 430 Answers
Evinrude E-tec 115 hp 2007 model No power to engine or hydraulics
Sounds like a fuse has blown, look behind your dash panel.
Mar 15, 2017 | HP Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
Aug 16, 2014 | Sierra International 18-6756 Marine Power...
Evinrude troubleshooting
Depending on age, the controls(relays) are either under the cowl or in a remote box but they are the same. Look for a fuse. Blown, you will have no action. Then check all connections especially to positive battery. but a bad ground will shut it down also.
Aug 05, 2014 | Clymer Evinrude/Johnson 5-70 Hp...
My 1977 85 hp Johnson motor will trim up but not down. I traced the wires from the trim switch to the solenoid and all are hot. I replaced the solenoid but it still will not work. I can cross out t
2 solinoides , one for up and one for down !!!! test trim switch then try swopping up solinoide to the down and problem could be solved !? check wires !
Jul 31, 2014 | Sierra Outboard Starter for...
Evinrude 50 HP outboard tilt and trim
sounds like the motor has give out . the clicking is probably the relays
Jun 14, 2013 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Evinrude 225hp will not power tilt batteries OK manual release will turn but still not able to tilt motor?
Check trim tilt switch (if that's ok ) Try the trim / tilt relay inside the engine cover.
Could also be limit switch above the trim motor up further under the motor.
My bet is switch or relay
Good luck
Aug 14, 2010 | Clymer EvinrudeJohnson Outboard Shop...
Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP Logo
511 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
