Question about Jura Capresso Impressa Coffee Makers & Espresso Machines
Jura Impressa F7 Fault 8
The machine won't make coffee; always getting Fault 8; ran it through the cleaning cycle as suggested, but the engine sounds very bad. It would make coffee for a week or so, sounding like it was about ready to die and now we are back to Fault 8. Now what? Sur Le Table will not help; who repairs these machines in Oregon?
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
SOURCE: Does anyone know how to take apart Jura Impressa
I hope this Jura F90 dismantling guide may offer some clues for your E-series machine. Before you start remind yourself of the risks. In case of a mess up, below I've listed a firm selling spares in Europe. In the UK it is assumed that it you can afford the BMW of coffee machines, you can afford to fix and service it too. However I haven't tried any of the servicing firms so they, and yours could be really, really helpful and cheap. You will need about 4 different torx; hexagonal and possibly unique screwdriver bits to remove all screws. A plastic pry tool (used for mobile phones) will help where plastic lugs hold on the side and top panel. Empty beans; water store and remove the waste tray. On the Jura F90 use pliers to undo two oval headed screws at the back at the top. You'll be able to remove the top panel after using a pry tool to disconnect two lugs at the front edge. You don't want to dismantle the coffee grinder and its hopper. Retain the hopper's rubber seals or glue them in place before you lose them as I did. Four screws hold the central back panel. Slide out a white key underneath the machine (can't recall how crucial this was). The side panels are removed by using a pry tool to release lugs all down the edge where these panels meet the front. Work slowly to manoeuvre the side panels off. If you simply want to clean the brewing unit externally then just remove the panel on the water side. Find the water inlet just where the water tank sits. A screw here allows you to remove a plastic piece - but take a photo of how it slots in. This gives access to the lower end of the brewing unit. If the plastic piece is still it the way, you can ease off the water pipe from the water inlet and put it aside. A number of different brands are made by one firm and branded. Thus the guts of these machines are similar. The brewing unit in the Jura F90 is almost identical in many machines. The screws and attachment places are different. The water inlet and valve are different. Cleaning the parts you can now see may fix a Malfunction 8 without removing and dismantling the brewing unit. The machine is partly operable in this state - cover the exposed electrical connections and remind yourself of the danger here. Thus you can switch off the power when the brewing unit's white wheel is at the top and then at the bottom. In this way you will get access to places causing any jam. You might just need to clear the inner chamber and path for two plungers with two large O-rings. You can see the water inlet nozzle with its o-ring which can perish and cause coffee or water to go to waste. Silicone grease only where the O-rings slide. Leave the other plastic parts ungreased. As I said you might get away with not disassembling the brewing unit. You can however buy a maintenance kit or a new brewing unit from the shop below. You will want to avoid removing the nylon water pipes - unless they're actually leaking. These pipes are held in place with a wire clip (remove with a flat head screwdriver). Ease the nylon pipe with its brass collar out of its socket. The pipe goes into an O-ring in the pipe's socket - this might fall out. Removing a brewing unit is like removing a car engine. The link at the shop below has a pdf (Anleitung_Jura_E.pdf) There is no need to force anything. On the Jura F90 the brewing unit is removed by undoing two obscure screws from the coffee grinder side. I had difficulty removing these and I wish I had taken time to find the right tool instead of wearing down the screwhead. On the electronic side there's an optosensor (encoder) unit held in place with a steel clip. You might remove this to access one of the two screws. At the bottom of the brewing unit, the water inlet valve is fixed to the machine with a single screw. Next, on the water tank side, you'll see two lines of screws that hold the assembly in place. The middle screws of the screws allow you to separate the unit from the gears. The top two holes don't have screws. Coffee machine spare part supplies are not as common in the UK as they are in mainland Europe. You'll find this web useful because of the pictures: www.kaffeemaschinendoctor.de is a German web shop for machine spares AND there's a pictorial of how to dismantle the Jura F90 as a pdf. Google will almost translate it). Juradoctor.de also carry lots of spares but don't seem to ship to my country.
Posted on May 09, 2010
espressonist
  • 1711 Answers
SOURCE: Jura Impressa F9
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Posted on Aug 23, 2010
SOURCE: jura impressa f7 decalcifying pressed rinse but
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Posted on Jan 19, 2011
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Drawer will not go back in for Jura Capresso impressa
For Jura F7 Series, "Tray Missing, can't put it back in". With a small flashlight, look in to the cavity which the tray and grounds container reside in. Along the right side above a slot to the end, you'll see a white micro switch. with a "Tooth Pick" simply press the switch inward (to the right) and hold till the machine cycles the Levcer / Flap up and out of the way.! Put your tray and grounds container back in and begin brewing!! -dh
Mar 17, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Error message Fault 5
The message 'FAULT 5' on the Jura Impressa F7, appears when there is a problem with the heating sensor. Normally it needs service or replacement. You can try to unplug it from the power supply for an hour and then open it again. See if it works.
Dec 22, 2011 | Jura Capresso Impressa F7 Espresso Machine
Jura impressa f7 decalcifying pressed rinse but does not show empty button as the manual says
Dec 31, 2010 | Jura Capresso Impressa F7 Espresso Machine
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jura fault 1
According to the Jura Coffee Machine Error List, you machine needs a service, have you made 5,000 cups since your last service?
Feb 07, 2010 | Jura Capresso Impressa F7 Espresso Machine
Coffee Makers & Espresso Machines Logo
955 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
