Question about Boating
Power trim stopped working
Does the power trim have a fuse/reset breaker?
  • e zink Feb 12, 2012
    THE ENGINE HIT A SAND BAR AND THE TRIM STOPPED WORKING. iS THERE A FUSE OR POSIBLY A CONNECTION WHICH HAS LOST CONTACT? 1998 150 HP EVINRUDE.
  • 430 Answers
Power windows
First check the power window fuse and relay.
The fuse is located in the underhood fuse box, it is maxi-fuse G (30A) {actually its' a 30A circuit breaker}. Make sure that power is getting to the circuit breaker using a testlight. Also check to see if power goes through the circuit breaker by checking its' other terminal while a partner operates (or attempts to) the power windows. If power goes in to the circuit breaker but does not come out, replace the circuit breaker. (some circuit breakers reset after a while, but I'm assuming you've have this problem for a while, so you're past the time it needs to reset)
Jul 08, 2014 | 1998 Ford Windstar
Kitchenaid superba double oven, stopped working everything dead, breakers not tripped. does not respond to any control.
Open the lower oven door and remove the 2 screws on the left and right trim pieces. Be careful not to drop the trim pieces and bend them. Locate and remove the screws on each side of the control panel and push up on the panel gently to get it off the hangers. Behind the control panel is an over heat fuse that has popped. It plugs into a harness on the back side of the panel. This trips/breaks it's connection from either the oven over heating the cleaning cycle or just from age.? Once fuse is replaced you're good to go. Hope this helps.
Aug 23, 2012 | Ovens
06 DODGE STRATUS WINDOWS INOP, NO POWER TO FUSE OR CIRCUIT BREAKER
If no power to the fuse panel for that fuse and circuit breaker, you may have a maxi-fuse burnt out in the power distribution box by or near the battery. Check all your fuses under the hood.
Apr 05, 2012 | 2006 Dodge Stratus
Power windows stopped working 2005 chevy impala
If they all just stopped at one time, it sounds like the circuit breaker is bad. That circuit breaker is located in the fuse panel inside the vehicle (below is a picture of its location). Also below is a picture of the fuse layout. The circuit breaker you may need to replace which is its only circuit that it works for (power windows & sunroof only if you have a sunroof) is the one in the diagram marked "RETAINED ACCSRY PWR BRKR". That breaker is supposed to reset itself after an overload but they do get weak after time. I would put money that is the problem. I hope this helps and good luck.
Jun 26, 2011 | 2005 Chevrolet Impala
All 4 of my power windows stopped working, and i can't find anything about a power window fuse in my manual
Power window usually don't have a fuse but an automatically resetting breaker. If all four windows stopped working at the same time check the body control module that is what manages the power windows. Good luck.
Mar 11, 2011 | 2002 Ford Explorer
The power windows on my 1991 Buick Century stopped working. they are all down and we can't get them to work.
Power Windows usually have an Automatic self resetting Circuit Breaker located neat the Fuse Box instead of a Fuse. This breaker has probably failed which has permanently isolated the power to the window circuit.
Jul 29, 2010 | 1991 Buick Century
All of my power windows have stopped working at the same time. what can I do to fix this?
It sounds like you've either blown a fuse or a circuit breaker. I think the power windows for the 1997 Grand Am are on a 30 amp circuit breaker located next to the fuse array in the fuse box. Look for a breaker labeled WDO. To reset the circuit breaker you may need to push it to the off position before you can return it to the on position. I believe the fuse box is located behind the glove compartment but if you don't find it there you can consult your owner's manual.
Jul 07, 2009 | 1997 Pontiac Grand Am
Refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Apr 03, 2009 | Refrigerators
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Boating Logo
74 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
