Question about Frigidaire ATF6000ES Front Load Washer
F10 Its not spinning at all and now I at least get an E10 error. Already replaced the pump about a year ago.
I have f10 fault code appearing on my ultima wmd960. Have replaced pressure valve with no joy.
I had the F10 error problem too. The machine would not accelerate up into spin cycle. I opened up the machine removed and checked all the hoses and water pump (located at the bottom rear of the machine). I took off the small black hose at the top of the machine and blew down it. Put it all back together again. It produced the same error. Fortunately I had a spare water pump I bought last year. I swapped it over with the old one and the machine worked perfectly. I think the pump was about £40. Hope this helps and if any tech guy can give an explanation please add to post.
Dec 11, 2011 | Washing Machines
F10 fault on an ultima WF865
F10 indicates the pressure switch isn't sensing a change in the water level.
Unplug the appliance and take the top off.
The pressure switch should be on the left near the top.
Take the thin tube attached to it off.
Blow as hard as you can down the tube for as long as you can.
Give the pressure switch a couple of good taps with your screwdriver handle.
Refit the tube and try the machine again.
Ensure the wiring and plug to the pressure switch are good.
If your hotpoint washing machine is not working and you feel it needs repairs and you are getting the E10 or F10 error code, this means there is NO cold fill and you should check and verify that the taps are on and that the hoses are not kinked.
The first thing to check is the taps, most machines will have the hot and cold fill supply plumbed via a hot and cold inlet valve placed under a sink or directly behind the machine, it is usually a silver valve with the Blue and some times a red flexible hose connected to it, the blue should be cold and if there is a red that will be the hot supply.
In the on position, the plastic switch located on the side of the in let vale should be pointed in the same direction as the arrow on the valve and in the off position it should be pointed across the valve, if it looks off, especially if your valve is under a sink where pots, pans, boxes and other item can get pushed up against it and could turn it off by accident, simply turn it back on, but do not force it, as forcing it could break it, and that could lead to a flood situation.
If the valves looks OK, but the washing machine is still not working and you still get the E10 or F10 error message, you now need to check for a kinks in the pipes, this will probably mean pulling the washing machine out from its housing to continue the repair.
At this stage you need to take in to consideration the fact that the washing machine will be heavy and connected to both the mains electrics and mains water supply and also that putting the machine back properly can often be harder than taking it out.
If you are unsure, you would be best advised to call a engineer, if you are not willing to pull the washing machine out you could still also check any part of the inlet flexible hose pipes that you can easily see, like in the cupboards and also to the side of the washer, if you see any kinks, you could try to remove the kink and test the machine again.
Error codes are usually machine specific and the diagnosis given here is for the hotpoint unit only, do not relate this diagnosis or error code meanings to any other make of washing machine
Thanks for using FixYa
Mar 04, 2011 | Hotpoint Ultima WF865 Front Load Washer
My whirlpool model/LSR8233JQ1 will not agitate or spin ut does everything else. already bypassed lid switch years ago because it broke,its still connected.
1. you possibly have a malfuncitoning timer
the timer is the control to the motor and the pump on a washer and each click represents function to the components on the washer such as the spin cycle ( the motor engages to spin the drum to extract the water to the pump at a given time on the timer.
Your machine need a service tech to determine this issue.
I hope this helps.
Jun 14, 2010 | Washing Machines
E10 on washer
this is just a general fault code.chance are the door switch needs to be replaced.you can also check to see if there is something clogging the drain pump.
Jan 23, 2010 | Frigidaire GLTF2940ES Front Load Washer
It has a E10 fault code now it stops every 2 min beeping and it not pulling in enough water or spinning right can anyone help pls???
E10 means that there is a problem with water inlet. If the control board does not detect required water level after a certain time after opening inlet valve, then you will get F10.
Check that the inlet hose is not kinked and that there is pressure in there.
Try tripping the circuit breaker for ten minutes to reset the timer board.
If you still get E10, then you usually need to replace the triple inlet water valve connected to water hose. Usually the valve solenoid has gone.
The solenoid can be tested using a multimeter set at Rx1. If solenoid is good it will return about 4 KOhms, if not it will return infinity.
Regards.
G.
Nov 27, 2009 | Zanussi FJD1666W Front Load Washer
E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 17, 2009 | Washing Machines
ATF7000es E10 fault
Hi - it sounds to me like the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw. I must have plenty of those to be spending my time here :-)
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
May 12, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
