Question about Patton MH761 Utility Heater
Need high/lowswitch pattonmh761
Switch that switches from low to high has red light in it, rocker switch.
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Need a wiring diagram for 3 speed patton floor fan
A three way switch has 3 terminals, these for floor fans operate by a rotary switch but can be adapted to use any 120V Rotary toggle or rocker type switch. technically your compartment (or room provided will determine which to use). I'd suggest you replace it with one like the one that no longer works. The one good thing about fans the direction they rotate in is already determined, and with a/c current it will work even if you connect it up wrong! If it work's then fine don't over think it
Oct 09, 2012 | Patton U2-1887HO Floor / Box Fan
I have an ACE brand dual control fan and light that I need help wiring. From the ceiling fan to the switch, I have a red, white, and black wire. The dual control has a black, yellow and red wire. I have...
The white to your fan will connect to the white in the switch box, The switch itself should have a wire labeled com or common. This is where the Hot in your switch box will attach. The other two wires will be your switch legs to theto the fan. (Red and Black)
http://www.broan.com/common/productDigitalAssethandler.ashx?id=e07a9916-6b3e-4456-b00e-2edfad475df2
May 04, 2017 | Broan-NuTone Broan 68W Dual Rocker Switch
How do i wire a miniature rocker switch red/brown and black wires
Any wire that is colored is hot, except for green and white, which is ground and neutral, If you have a line coming in to your switch, and 3 loads going out, red, brown, black, then those should be the 3 lights. The white wire will be connected to white, and the green to ground. If you don't have 4 colored wires, then you have 1 switch too many. Let me know if this is making sense.
Apr 14, 2010 | Leviton 003-1755-W Three Rocker Switches
Great Little heater: I need the Off-On Rocker Switch
go to radio they have many diffrent rocker switches if you cant find it there then call me 985 210 7291 i will get you one cheep ok jason
Apr 09, 2010 | Vornado EH1-0014-01 Compact Heater
2006 Dodge Ram 3500 diesel 4x4.I want to install four KC Rally 800 HID lights on my truck. I would like all 4 lights to go off when I switch to low beam. The lights will be on relays and rocker switches...
I cant tell you off the top of my head, but the easiest way is as follows.
Turn on your low beams, with a test light or volt meter, find the wire that powers the low beams (it will lose power when you switch to high beam).
Once you have found that wire, wire the lights and relays as if the hot low beam wire is your "switch", it will supply the switch power source the 12v it needs to turn on the power to the lights.
Hope this helps ya out.
Nov 08, 2009 | 2006 Dodge Ram 3500 Truck
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Patton MH761 Utility Heater Logo
52 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
tractorman44
tractorman44
Jay Finke
Jay Finke
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
