Question about Hitachi C12RSH 12" Sliding Dual Compound Miter Saw with Laser Marker (Reconditioned)
Laser issue with Hitachi C12RSH Saw
The laser on my saw doesn't come with the trigger.
4 Suggested Answers
lessmith49
  • 5 Answers
SOURCE: blade brake not working 1/2 the time on Hitachi C15FB chop saw
d70d03f.jpg3f82e5b.jpg38ca90b.jpg4367374.jpg063ef2e.jpg1add57c.jpg98eea3c.jpg The first picture is the only one I could find of your saw.
All saws are fitted with carbon bushes that contact the armature of the electric motor.
In time the carbon which conducts the electricity wears down, as they disintegrate there are particles of broken carbon connect with the armature giving an intermittent burst of power, eventually the bushes no longer contact the armature and the saw does not work at all.
The next photos show the approximate position of the cover to access the bushes, there is one one each side of the housing.
They usually unscrew and expose the spring plate the bush is mounted on, gently pull this out.
As you can see the bush is worn in a concave shape, and that the wide side is breaking up.
If this is your problem then take the bush and model number of your saw to a supplier or spare parts shop or the hitachi web site to get replacements.
Hope this helps.
If anyone finds this information helpful please tell fixya
Cheers
Les
Posted on Feb 13, 2009
  • 109 Answers
SOURCE: My Hitachi 10" miter saw laser beam has stopped functioning
Have you tried new batteries first?
Posted on Mar 27, 2009
  • 885 Answers
SOURCE: The laser stopped working on Hitachi 12'dual
The laser modules in saws are usually powered by induction from the spinning saw blade. Since your saw is only three months old hopefully you either registered it with Hitachi when you bought it or you still have your receipt as this type of failure would be covered under warranty. Call Hitachi, they may send the part to you if you are comfortable with doing the repair or they will tell you where the nearest Authorized Service Center is for warranty work. Hitachi's number is: 800-706-7337 or 770-925-1774.
Posted on Jan 27, 2011
Hitachi c12rsh brake
There are a few things that can cause this:
1) Check the brushes - make sure they are not severely worn and make sure they travel freely down the brush tube & contact the armature well.
2) If the brushes are OK the problem is most likely the switch. Tools with a brake have a 2 pole switch - one set will be normally open and one set will be normally closed (Most switches have a diagram printed on them) Disconnect the leads (keeping track of where you removed them) and using a continuity tester check the switch - you should get a reading between the normally closed contacts and lose it when you pull the trigger. Most likely you will find you are not getting a reading on the normally closed side and that would be your culprit. Hitachi C12RSH 12 Sliding Dual Compound Miter Saw Parts
Mar 16, 2015 | Hitachi C12RSH 12" Sliding Compound Miter...
The laser stopped working on my Hitachi C12LSH miter saw. Now I need to determine whether the laser burned out or if there is another problem. I need to know if the laser works on 120 volts so I can t
clean laser and wire, also clean circuit board and heat circuit board wit the heat gun. if it will not work please relapsed laser. laser not work on 120 volts. laser work DC volts.
Oct 21, 2014 | Hitachi 12" Sliding Dual Compound Miter...
New hitachi miter saw can't loosen the clamp lever
Any answer to this question? We are having the same issue.im sure it's something I'm not realizing but need to get this thing unstuck
Apr 14, 2013 | Hitachi 12" Compound Miter Saw with Laser...
My saw was received with the saw blade not tracking parallel to bottom guide. It appears to be shipping damage. Is there an adjustment to correct this problem?
I noticed your post after I just posted the same problem (you worded it better). Did any magic answer other than returning the saw (presumably damaged in shipping) ever materialize?
Feb 12, 2011 | Hitachi C12RSH 12" Sliding Compound Miter...
The laser stopped working on Hitachi 12'dual compund mitr saw,are there batteries that can be replaced or does the unit need to go to a tech? The laser only worked for a month and the saw is only 3 months...
Jan 27, 2011 | Hitachi C12FDH 15 Amp 12Inch Dual Bevel...
12" Compound Miter Saw with Laser Marker - C12FCH: Electronics including the laser marker do not func...
Some lasers work off batteries. If yours does, you might want to change the battery/batteries.
May 17, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Hitachi C12RSH 12" Sliding Dual Compound Miter Saw with Laser Marker (Reconditioned) Logo
93 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
