Question about Frigidaire GLTF1670A Front Load Washer
Front load washer
The rubber boot at the door of my front load washer has come loose. When I tried to push it back on the seal it came off more. I think I have to remove front of washer to place boot back on to unit. Give me answers? Thanks
  • 1 more comment
  • Anonymous Jan 17, 2008
    This is the second time I have written about this problem. My seal is not loose but does hold water so when I open the door water spills out on the floor. I would like someone to get back to me and explain if this is covered under my warranty I have with you. As I said this is my second time writing to you. My email address is randsflint@hotmail.com and my phone is 937-725-7549. Please get back to me on this.
  • HVAC Guy May 11, 2010
    Catriver,
    In your post reply to Hitchhiker you said there was a service flash, do you call the factory to verify that and do you order it direct? It seems glued on well, you don't have to glue the new one?
  • Anonymous Mar 16, 2014
    The drum has pulled away from the door seal. There is a finger-width space between the drum and the seal. The machine still answers the controls.
    President:
  • 878 Answers
Hitchhiker, you don't have to remove the front of the washer. The original boot was glued in areas around the door. They came out with a new design because of water leakage on the bottom. The new kit, part number 5303937187 comes with a spring that holds it on to the panel. You can do one or two things, if you don't have the leaking problem, glue the boot back on. Or you can order the new kit, it comes with instructions and replace the whole boot. Check it out, it might be covered under service flash #26-758BR. In any event this job can be done by leaning the washer back against the wall to make room between the tub and front panel. You are going to need an assist, it's better with 2 people. Catriver...post back.
Posted on Aug 10, 2006
We have water leaking out of the front of our washer not from the door but from just below the door. Is all over the floor??
most likely you have a hole in the boot seal,the rubber piece in between the door and the tub,also open the door and wipe the bottom part of the door on the plastic window,i've found pieces of hair there and the water travels down the hair and leaks through the door.if that's clean you have a hole in the boot seal,open the door,spread the rubber boot open and with you fingers feel all around the rubber boot
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
The door leaks on my whirlpool front load model wfw8300sw03, looks like the door isnt sealing tightly, if I push on the door it stops lealing, any ideas?
you might have a bent door hinge, but most likely you have a worn door boot. its the grey rubber thing that the glass seals to.
try to lift up on the door to get the hinges back into place and if that doesnt work then you might need to replace the door boot.
look at the edge of the boot where the glass hits it. the glass must seal to the rubber and if the rubber is worn or torn then it wont seal.
not an easy piece to replace but it can be done. i wouldnt recommend trying it first as you will find it very tight to get your hands into and the clamps are hard to figure out as well.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from whirlpool front loading washer when washing heavier loads
Check your rubber seal in the washer by the door and make sure your getting a good seal. Part of the seal has probably pulled loose.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber gaskets came out
remove spring retainer ruber door boot remove the rubber.looking for the clamp loose it put the door boot back in the tub(drum)tie the clamp go revert the procedure(take out)good luck
Sep 29, 2008 | GE WSXH208A Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
479 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
