My Samsung gem is not connecting to internet how can I fix it
    Problem Solver:
  • 17 Answers
Try asking your service provider for the internet settings, or reset phone to default settings
Posted on Feb 16, 2012
Door ajar light stay on
Door ajar switch is bad or you have a wiring problem ! Which door ?
B1322 Door Ajar Driver Circuit Short to Ground GEM/CTM REFER to Section 417-02 . B1323 Door Ajar Lamp Circuit Failure GEM/CTM REFER to Section 413-01 . B1325 Door Ajar Lamp Circuit Short to Battery GEM/CTM REFER to Section 413-01 . B1330 Door Ajar RF Circuit Short to Ground GEM/CTM REFER to Section 417-02 . B1334 Decklid Ajar Rear Door Circuit Short to Ground GEM/CTM REFER to Section 417-02 . B1338 RR Door Ajar Circuit Short to Ground GEM/CTM REFER to Section 417-02 . Inspection and Verification
  1. NOTE: The generic electronic module (GEM)/central timer module (CTM) must be reconfigured upon replacement. Refer to the scan tool help screen on the configuration card to program the tire size and axle ratio.
    The warning lamps are a GEM/CTM controlled system; refer to Section 419-10 .
  1. Verify the customer concern by operating the system in question.
  1. Visually inspect for the following obvious signs of mechanical and electrical damage.
    Visual Inspection Chart Mechanical Electrical
    • Switch(es)
    • Fuse(s)
    • Damaged wiring harness
    • Loose or corroded connections
    • Circuitry
    • Bulb
  1. If the concern remains after the inspection, connect the scan tool to the data link connector (DLC) located beneath the instrument panel and select the vehicle to be tested from the scan tool menu. If the scan tool does not communicate with the vehicle:
    • check that the program card is properly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the scan tool still does not communicate with the vehicle, refer to the New Generation STAR Tester manual.
  1. Perform the DATA LINK DIAGNOSTIC TEST. If scan tool Tester responds with:
    • CKT914, CKT915 or CKT70 = ALL ECUS NO RESP/NOT EQUIP, refer to Section 418-00 .
    • NO RESP/NOT EQUIP for GEM/CTM, go to Pinpoint Test E.
    • SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and perform self-test diagnostics for the GEM/CTM.
  1. If the DTCs retrieved are related to the concern, go to the GEM/CTM Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If no DTCs related to the concern are retrieved, proceed to Symptom Chart to continue diagnostics.
Aug 20, 2016 | 2002 Ford Explorer
My battery drains over night. i can hear a relay under the dash clicking. i remove no. 27 fuse and it stops. what is causing this?
Check your owners manual for the number 27 fuse to see what it is. Checking online I see it as a 15 Amp, Under hoop lamp, Map lights, Glove box lamp, Dome lamp, Visor lamps, Accessory delay, Dimmer switch illum. and 4x4 system. check each one to see if the bulb is blown but left on, at least if it's a light. It that doesn't do it, research how to check accessory delay and 4x4 system.
Mar 20, 2015 | 1996 Ford Explorer
I need clash of clans gems is there any way to get them for free?
No. If you see anything on the internet that says you can get gems free, don't believe it. One way or another you have to pay for them - maybe through a scam, if you aren't careful. There are a lot of scams on the net where gems are concerned.
Mar 05, 2015 | Android Apps
How can I connect XP to my laptop
Hello, Yes this can be put on laptop if you have a licensed software. But microsoft stop supporting this and there are lots of places on the internet that xp won't work.
May 17, 2014 | Gem Genesys Xp Professional Multimedia...
Hi, Recently I try to purchase "gems" for the game svz2 The game stuck and I receive no "gems", after few days I receive my credit card statement and shows that I purchase from you 3-4 times, that happened...
as from our part on Fixya, we can't help you with this issue.
But to fix it, you need to contact the developers/ adminstrators of the app page/ game with details on what happened; how; when e.t.c.
Remember! Don't reveal personal information.
Oct 29, 2013 | Computers & Internet
Body control gem module f250 2001 ford
The windshields leak on the left side
& water gets into the delayed acc relay
& GEM Module connection
Read up on that on the internet
Haven't found a windshield leak solution yet
to help you there
Feb 26, 2013 | 2001 Ford F250 Super Duty Super Cab
Ford Explorer wipers, power windows, doom lights won't work
Are u assuming the GEM module is at fault ? Did you or your local auto electrician check for DTC'S - diagnostic trouble codes?
GEM/CTM Wiggle Test Diagnostic Trouble Code (DTC) Index DTC Description DTC Caused By B1317 Battery Voltage HIGH GEM/CTM B1318 Battery Voltage Low GEM/CTM B1322 Driver Door Ajar Circuit Short to Ground GEM/CTM B1330 Passenger Door Ajar Short to Ground GEM/CTM B1352 Ignition Key-In Circuit Failure GEM/CTM B1410 Driver Power Window Motor Circuit Failure GEM B1438 Wiper Mode Select Switch Circuit Failure GEM/CTM B1441 Wiper Mode Select Switch Short to Ground GEM/CTM B1446 Wiper Park Sense Circuit Failure GEM/CTM B1450 Wiper/Wash Interval Delay Switch Input Circuit Failure GEM/CTM B1453 Wiper/Wash Interval Delay Switch Input Short to Ground GEM/CTM B1462 Seat Belt Switch Circuit Failure GEM/CTM B1577 Park Lamp Input Circuit Short to Battery GEM/CTM B1610 Illuminated Entry Input (From RAP Module) Circuit Short to Ground GEM/CTM
Did you an your auto electrican check power an grounds for the GEM ? Voltage drop testing ? . Did you check power an ground circuits for the affected systems . Working when they want sounds more like a loose connection somewhere .
ECM Inputs and Outputs Diagnosis
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The Wipers Are Inoperative
  • CJB Fuse 16 (30A).
  • Circuitry.
  • GEM/CTM.
  • Multi-function switch (13K359).
  • Wiper run/park relay.
  • Wiper HI/LO relay.
  • Wiper motor.
  • DTC B1431.
  • DTC B1432.
  • DTC B1438.
  • DTC B1450.
  • DTC B1840.
  • GO to Pinpoint Test A .
Plus looking at GEM scan data on a factory scan tool .Too many people miss diagnose these system's because they don't have a clue .
Jul 03, 2017 | 1999 Ford Explorer
I need a manual for samsung gem phone, where do I get one, I need help to learn how to use the phone so I don't have to return it cuz it is smarter than I am, Thanks, Jean
For the operating manual type "Samsung gem Operating Manual"into your search bar on your PC and download the manual for free.Save it to your PC and install where you then can read at leisure to get to know the phone.You will need Adobe reader and that you can also download if you do not have it on your phone Cheers.
Jul 07, 2011 | Samsung Cell Phones
My moms 1998 Ford Taurus's battery dies with the cables normally connected. If you take one of the cables off the battery, it works fine. You just need to reconnect before you start the engine. We were...
It sounds like something is drawing power with the key off. It could be the GEM module but I doubt it. There is a draw somewhere. Connect battery and pull fuses one at a time to see if curent drain stops. You will need an ampmeter in series with the battery and the postive cable. Expensive. Get one from pick n pull salvage yard real cheap.
  • Check the following fuse junction panel fuses: fuse 23 (5A), fuse 20 (5A), and fuse 8 (5A).
  • Section 13-09A: Gauges/Warning Devices, Chime/Buzzer System 1998 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/16/1998
    Generic Electronic Module (GEM) Removal
    The generic electronic module (GEM) is connected to the rear of the fuse junction panel (14A067) .
    1. Disconnect battery ground cable (14301) . Refer to Section 14-01.
    1. Remove two nuts retaining fuse junction panel to dash panel (01610) .
    1. Pull upper ears of fuse junction panel down out of retaining bracket.
    1. Disengage locking tangs and disconnect three harness connectors from bottom of GEM.
    1. Turn fuse junction panel over and remove screw retaining GEM to fuse junction panel .
    1. Disconnect and remove GEM from fuse junction panel .
    Installation
    1. Follow removal procedure in reverse order.
    1. Tighten GEM to fuse junction panel screw to 1-2 Nm (9-17 lb-in).
    1. Tighten fuse junction panel retaining nuts to 4-6 Nm (36-53 lb-in).
      Item Part Number Description 1 14B205 Generic Electronic Module (GEM) 2 - Mounting Ear (Part of 14A067) 3 14A067 Fuse Junction Panel 4 - Screw (Part of 14A067) 5 - Generic Electronic Module (GEM) to Fuse Junction Panel Connector A - Tighten to 1-2 Nm (9-17 Lb-In)
    Dec 17, 2010 | Ford Taurus Cars & Trucks
    Computers & Internet Logo
    David Payne
    David Payne
