Question about Singer Sewing Machines
Rotating hook bobbin case cushion spring location on singer 9410
How does the spring cushion go?
SOURCE: Singer 9410 Bobbin
a need number of spire
Posted on Dec 26, 2007
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 6 Answers
SOURCE: Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Posted on Mar 12, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 51 Answers
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Posted on Sep 06, 2009
My machine won't pick up the thread at the thread take-up? What should I do? It is also making a loud sound.
The loud sound suggests that the moving needle and the moving parts of the bobbin system are no longer timed properly>
If this is the case you cannot fix it yourself and I can"t tell you how to do it
A qualified technician can do it>
Sorry I cannot be more help but my layman knowledge does not cover that!!!!!!
Apr 22, 2015 | Singer 7258 Sewing Machine
Need help reassembling bobbin area.
You didn't state what model you have, and that makes it tougher to help you.
I'm going to take a guess here that the part that fell out is a silver U shaped part located on the right near the bottom of the bobbin basket (holds the case). If that's the case, it's called a "cushion spring" and can just be reinserted by hand. It is part of the assembly that prevents the case from moving while the thread is unspooling from the bobbin during operation.
Oct 30, 2014 | Singer Sewing Machines
How can I replace bobbin case on Singer Inspiration 4220
Download the instruction manual free from the Singer Sewing Machine site, and go to page 62. It will show you how to reinsert your bobbin case.
The flat part goes UNDER the needle; there is a projection on the right side of the case towards the bottom that must rest against a silver part that is actually a cushion spring and prevents it from spinning. It's pictured in the manual.
It's helpful when reinserting it to insert it slightly clockwise of where it should go--that is, placing the flat part slightly to the right, then twisting it counterclockwise into the correct position, with the case's projecting resting against the spring.
Jun 21, 2014 | Singer 7442 Mechanical Sewing Machine
Bobbin housing has come out, I cannot get it back together
Hi This machine uses the standard class 15 bobbin. It sits inside a bobbin case that has a finger that needs to be located in a retaining slot. It the whole lot, bobbin, case, hook assembly and retainer have come out simply turn the machine over so that these parts can be fitted downwards. fit the hook, then the retainer and lock it into position. Put bobbin into case pull thread under spring. Lift tab on case and put it over the hook's central pin and release tab. It should now be locked in position
Feb 17, 2014 | Singer 2250 Tradition
My bobbin keeps popping out. There is a small hole under the bobbin casing. I pulled what appeared to be a wick out of there. It was frayed on the end and I thought it was part of my tension problem. Is...
Hi, the wick will not interfere with your tension, it is there to oil the hook shaft.
If you e-mail me at dupina@mweb.co.za i will send you the instructions and pictures on the bobbin case settings. Take special note of the retaining bracket, plate spring position and the Reverse rotation stopper. It sometimes happens that the reverse rotation stopper bends upwards, allowing the bobbin case to move underneath it. Press it slightly down to prevent this.
Aug 25, 2011 | Singer Touch Sew 7462 Mechanical Sewing...
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Sewing machine bobbin casing is loose and can't get it back in!
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Jul 20, 2009 | Yamata FY700 Mechanical Sewing Machine
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Sewing Machines Logo
91 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
