Question about Compaq Presario 700 470024-192 Notebook
No sound dear digi, Actually, i formatted my laptop 2 days back. The format was sucessfully completed. But, after formatting it shows no audio device. There is no sound in my notebook. I tried different options such as installing sound driver from HP compaq site matching my model but it didn't work. From other sites also i downloaded different drivers n cards such as Driver magic and conexant audio driover, but all in vain.plz help me what should i do so that i can play music and movies on my notebook. Whether i should install sound driver or device and which one. If u can provide me any such files that can resolve my problem i will be grateful to you. My model is compaq presario 765 TU.
    Genius:
  • Compaq Master
  • 1,250 Answers
The vista driver is available on compaq's site, for windows xp just go to compaq site, support , select live chat option, there they will give you the link on your email id
Posted on Oct 27, 2008
I have open office.org as default for microsoft office but cannot get sound on open office version of powerpoint.
The number of audio formats that the OpenOffice media player, actually JMF, can play is so limited that unless the audio file attached to the slide show is in one of those few formats, it you won't get a sound. Simple as that.
There is a way to expand the number of formats JMF can play, but after over two hours of trying to download and compile the file, forget it. More trouble than it is worth.
Jun 30, 2010 | HP Pavilion dv6000z Notebook
After formatting laptop there is no sound
You need to install the audio driver. (and others if they are missing when you open the device manager)
If you download and install a program called Drivermax, it will help you find any missing drivers for your system. You can pay $10 and use it for 30 days, or you can download 2 drivers a day for free.with it. It's a great little program. Get it here: http://www.innovative-sol.com/drivermax/
If this has helped you, please vote:
Jun 15, 2010 | HP Business Notebook 530
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
MyMusix PD 6030 persistently displays flash error! please backup the data and format the player. This happened after I tried to replace an existing playlist with a new one.
I would recommend you do back up your files to the computer and then format the player.
Q: How do I format my PD-6030?
A: There are various way to format the PD-6030.
With Windows XP, go to Start, All Programs and select 'My Computer'. Then see if there is a device called an 'Audio Player' listed there. If so , open the Audio Player and right click the item named 'Internal Storage' and select 'Format'. Once the format is complete, unplug the player and turn it on. Once it turns on and says 'No Files' plug it back in to your PC and add the music back to the player.
With older version of Windows, the player will show up under 'My Computer' as a 'Removable Disk'. Right click that and select "format'.
Oct 16, 2009 | MyMusix Audio Players & Recorders
My pen dive not formating
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
May 05, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Cannot put downloaded videos onto iriver e10, suggestions?
why not try the avi format video?
Just get this tool to help you.
1. load your file to Video Sharer
2. choose AVI format
3. click" convert" button.
Then you will get the right format.
Here is the tool for you: http://www.asharer.com/download-video-sharer
Mar 13, 2009 | iRiver E10 Digital Media Player
I need to format the laptop
If you do not have the drivers for the devices that are installed on your laptop, then download from the IBM/Lenovo WEB site, make sure they are for your model laptop (eg. Video, audio, modem LAN etc.) before you format and reinstall Windows..
Follow these steps.
1. Boot up the laptop and press F12 function key to get a list of boot devices, select the CD drive.
2. Insert your Windows XP CD into the CD drive.
3. Press the space bar to start the bootup from CD
4. During the install process you delete the existing partition/s and create a new partition.
5. The next step is to format the partition - do a NTFS full format not a quick format
6. Follow the instructions to install windows.
7. After Windows completed the installation ,check on which device drivers didn't install and install these drivers.
Feb 05, 2009 | IBM ThinkPad R52 Notebook
Samsung YP-U2 MP3 Player won't play songs
Hey,actually mine is aYP-U2 ZW/XSA white colour piece.
What happened to it I don't Know........Only its showing songs folders & It also showing some AutoRun.........It's not showing any settings etc when I go back.............
could u Please tell me How to resolve this problem?
Oct 04, 2007 | Samsung YP-U2X Digital Media Player
Compaq Presario 700 470024-192 Notebook Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
