Question about Husqvarna 28cc Hand Held Blower HVH 125B
How to replace primer bulb on husqvarna blower 125b
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Posted on Aug 02, 2011
Wont draw a prim
check primer bulb for cracks and leaks .
check hose into the fuel tank for cracks and leaks
pull the carby apart and replace stiff diaphragms.
Jul 23, 2015 | Husqvarna 28cc Hand Held Blower HVH 125B
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Primer bulb will not prime
Sounds like it could be a number of faults.
1. Crack in the primer bubble its self, not allowing the creation of pressure or vaccum.
2. The plastic primer base has a valve in it. That could either be blocked or damaged.
3. Blocked up fuel line (not very likely)
4. Hole in the fuel line which is sllowing it to suck air up and not fuel.
I\'d be putting my money on 1 or 2.
Jul 03, 2013 | Husqvarna Garden
Husqvarna 125B will start and run but once it heats up it stalls and will not start until it cools down
sounds like it's going lean lack of fuel check for cracked fuel lines,primer bulb or leaky carb to engine gasket
Aug 25, 2012 | Husqvarna Garden
How to replace a primer bulb
should be pretty easy, four screws lift retainer clean & replace with new bulb.
Jan 22, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
What are the steps to start my husqvarna 125b handheld gas blower
Put fresh gas/oil mix (if it is a 2 cycle) in the tank.
Put the choke on. Push the primer bulb 3-6 times. Pull the cord until the engine sputters. Put the chock to 1/2 way, pull cord again. Should start and run a bit with choke set there, then in about 10 seconds, put the choke completely off.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Husqvarna Garden
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna 28cc Hand Held Blower HVH 125B Logo
1,583 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
