Question about Dryers
My tumble dryer is making a terrible when the drum goes round and it keeps tripping the fuse, does anyone know what it maybe?
    President:
  • 2,468 Answers
Sounds like the motor is seizing up from dry bearings and dragging enough to trip the breaker from excess current,open up the unit and remove belt off motor pulley and spin motor shaft,it should free wheel and coast to a stop,if not its getting bad
Posted on Feb 13, 2012
4 Suggested Answers
SOURCE: Beko tumble dryer not drying.
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Posted on Aug 20, 2008
  • 63 Answers
SOURCE: tumble dryer drum only starts when i start it first by hand
starter capacitor went bad on motor... replace
Posted on Mar 13, 2009
  • 8404 Answers
SOURCE: terrible noise coming from tumble dryer when drum
Is this a second "terrible noise question" in 12 hours or did I already answer this?
Check the front bearing surface of the drum, which rides on the inside of the front panel of the drier (It rides on a ring around the door).
If there are screws in the top, rmove them then pop it up - gently (so you dont damage the finish) pry the top up from the front panel. Remove the front panel (screws or spring clips or both) remove the front. The drum is now free to come out. check the surface that runs on the door. becareful you dont pull any wires off the door switch.
maybe you can fix it - maybe you should replace it. get parts ar local appliance parts store, FixYa.com advertiser or www.repairclinic.com
Thanks for using FixYa.com.
Posted on Nov 01, 2009
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
Zanussi tumble dryer tds 280w front gasket snapped
it is the drum gasket that goes round the inner drum that forms a seal and acts as a buffer for the drum to ride on if not replaiced the dryer will get noisy and wear the drum out they are stuck on with a glue
Nov 06, 2011 | Dryers
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
Tumble dryer is very noisy
i had the same problem.it ended up being the bearing that holds the drum in place.it had worn that bad that the drum was rubbing the bottom of the dryer.the bearing is located on the back of the dryer if the bearing is worn there will be like black dust around the area.this does stain so be carefull
Feb 19, 2010 | Miele Dryers
Terrible noise coming from tumble dryer when drum goes round.
Nov 01, 2009 | Dryers
Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Apr 10, 2009 | Dryers
Tumble dryer drum only starts when i start it first by hand
Mar 12, 2009 | Dryers
GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 04, 2008 | GE Profile Harmony DPGT750EC Electric...
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
Apr 23, 2008 | Dryers
Miele Dryer heater bank
Heating element
Thermal fuse
Wiring
Mar 21, 2008 | Miele Novotronic T220 Electric Dryer
Dryers Logo
Top Dryers Experts
