Question about Ovens
Oven won't light
Oven worked last night, wont work today. can hear a clicking noise when temp. setting is turned. Burners on top of stove work. Took bottom plate off bottom of oven and can see ignighter but noting is happening. not a self cleaning oven
  • Anonymous Mar 20, 2014
    When I turn on the burners, the clicking noise does not go off after the burner lights. It remains on. It's the same for all the burners. We've cleaned the pistons at the beck of each burner. What else can we do?
  • 3 Answers
I am assuming this is a gas stove. You probably need a new flint in the igniter. Simple problem. Check your local hardware store for flint, and refer to your manufacturer's manual for how to install it. If it's not there, a quick call to a service technician should answer the problem. hope this has been helpful.
Posted on Oct 24, 2008
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Oven will not light
there is a eletric thermocouple at the bottem back of oven unplug the stove remove broiler draw to get access to this part remove small screw disconnect wire replace with new one to order part you will make modle s/n off data plate good iuck later
Apr 01, 2009 | Ovens
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Mid 90's Magic Chef gas stove
hi there,
since you can smell gas, you have a gas leak. i would recomend checking and cleaning the gas valves. if you can hear sparking, that means it's just the valves. sometimes cleaning the rods will fix the problem.
Oct 10, 2008 | GE JGRP17 Gas Single Oven
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven
Is this an electronic control oven...touch pads to set temp? May have a bad ERC. Electronic Range Control. Also check oven sensor. This is steel rod in oven in back wall near top on left or right. Check ohms from the rear where it connects to harness. Disconnect at harness and measure resistance of sensor. Most are around 1.1k.
Oct 07, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
199 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
