Mother board powers up when power supply is turned on Does nothing
Has soon as the power supply is turned on the motherboard powers up. I get nothing, no beeps, no video. I have changed the battery, Removed the ram and video card and disconneted the motherboard from the case. I even use another power supply and has soon as I turn on the power supply the board powers up. I know its old and its just a back-up computer but I can't figure out why. Any ideas?
  • 27,725 Answers
Try your cmos battery make sure it has dust free connection and is securely seated and has plenty of charge
some motherboards cmos batteries are soldered in
hope this mother board powers up when power supply is turned - 2027.jpghelps
Posted on Feb 13, 2012
joey64
  • 209 Answers
SOURCE: video card not connected to power cable
remove your video card uninstall if you ugraded this and temporarily use the on board then switch on. this way you can determine if your motherboard is also having a problem if you hear a beep beep sound your ram memory shold be taken out clean it then transfer to other slot.
Posted on Dec 06, 2007
SOURCE: MSI MS-6754 mother board won't boot and beeps when I swap processors
Ya know. I was trying a 533 FSB processor I see now that my motherboard only supports 400! Standby. Let me get a 400 and see if it cures my ills! Ahhhhh............
Posted on Sep 09, 2008
techcrazy
  • 72 Answers
SOURCE: Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Posted on Feb 04, 2009
  • 134 Answers
SOURCE: No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Posted on Feb 17, 2009
shibuda
  • 1812 Answers
SOURCE: Asus M4A785-M will not post.
All I read properly .Please remove power supply from HDD and CD /DVD RW. If you face the same problem Open the mother board on a open place and try it again ,because there are some particles witch has made the short sercit in your M. Board.Cgeack all voldage socket plkaced properly,MAY BE CAN SILLY MISTAKE FOR 4 pin socket .
If you face same problem please install in another mother board .Post me please imediate next result.
Posted on Dec 12, 2010
The power shuts down as soon as it comes on. Fans start, lights come on, then it turns off.
it may be your power supply : if one voltage aren't good the mother board automaticaly shutdown to prevent damage
or it could be CPU, RAM or motherboard but i think that it's the PSU
Oct 28, 2012 | Intel Motherboard
Power supply LED (Green) turned to red and blinking and nothing works
Power Supply is bad. Plain and Simple. Replace it. Regards, joecoolvette
Aug 31, 2012 | MSI Hp Compaq Evo Ms-6541 Rev 1.0...
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
My ga-ma785gm-us2h won't turn on, no power or nothing. I hit the power switch on the front of the case but nothing happens no fans spin or anything.
check the power supply is working properly, if the power supply is connected to the mother board and also check the front panel switch is connected to the board
Jan 16, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
Power supply or motherboard dell 4600
Ok, you stated that the power supply cooling fan was running at this time. unfortunately, this is not the power supply unit that has failed. the mother board has actually failed in this case. If the power unit was damaged, the cooling fan would not spin. You will need tp replace the mother board in this case. it has failed.
This is not a novice situation. we recommend a service tech for this type of repair. if it was a power supply issue, it would have been quite easy to replace but, this is not the issue here. it the mother board.
Jun 22, 2009 | Dell Dimension 4600 PC Desktop
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
Mother board dead for all
pleace help me..i need a audio driver for p4vmm2 audio driver
Oct 15, 2008 | EliteGroup P4VMM2 Motherboard
No Power of a Compaq Presario Computer
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Feb 23, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
