Question about Sony Network Walkman NW-A3000 MP3 Player
Message:app failed to start because NTMSAPI.dll not found
When I try to got into Connect software it comes up with that message and then says Windows stopped it working. Have uninstalled and then reinstalled many times but still same problem. I use Windows Vista and used to use Windows 2000. Any suggestions?
  • Anonymous Dec 02, 2008
    nw a3000
  • littlejodie Dec 09, 2008
    I have the same problem, I have just installed the software the player came with on my new laptop but the it will not run, get the error as described above. Don't know if it makes any difference but I am now running on Vista.
    Problem Solver:
  • 5 Answers
Have tried uninstalling the software and installing the new version downloaded from Sony's site?
Posted on Feb 07, 2009
Uninstall failed due to v4Bar.dll not found
you can replace the old one or uninstall it from your computer and download a new one
Dec 17, 2013 | dictionaryboss.com
Tip
How to solve FLTLIB.DLL was not found issue
moz-screenshot.pngYou might have get this message "This application failed to start because FLTLIB.DLL was not found. Re-installing the application may fix this problem"
Its because the FLTLIB.DLL is missing or corrupted. you can solve this issue
You can download FLTLIB.DLL from here and you can copy and paste it in directory,means
c:\windows\system32
or
go to RUN and type regsvr32 "c:\windows\system32\fltlib.dll and hit enter .Press Ok when you get successful message.
on Aug 28, 2010 | Computers & Internet
Tip
Xpcom_core.dll file error
The xpcom_core.dll is included with Mozilla (Firefox) enables the Mozilla program to be an actual framework. The xpcom_core.dll module provides a development environment that includes file abstraction, component management, memory management and object message passing for software developers.This DLL allows for the access of components that can be contacted from a web browser or scripted from any application from Mozilla.
If you're having an issue with your xpcom_core.dll file, the exact message displayed will vary. A few examples are listed below:
  • "The dynamic link library xpcom_core.dll could not be found in the specified path"
  • "Missing component xpcom_core.dll"
  • "This application has failed to start because xpcom_core.dll was not found"
  • "xpcom_core.dll is not loaded"
This dll file can be downloaded by clicking here
on Apr 25, 2010 | Microsoft Windows XP Professional SP2
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Iiriver 3 failed to start SMV.dll was not found
Search google for smv.dll. A lot of people have this problem and apparently the manufacturer says you need to remove the current version completely and then download the latest version which fixes the problem from the manufacturer's website.
May 02, 2010 | Dell Computers & Internet
Im having problems
Hey there
you can get the .dll file here
http://www.dlldump.com/download-dll-files_new.php/dllfiles/N/ntmsapi.dll/5.1.2400.21808/download.html
download the file and drop it in the root folder of the connect player application on your C: drive
Oct 08, 2007 | Sony NW-A1000 MP3 Player
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Dec 21, 2006 | Quest Software SQL Navigator Professional...
Sony Network Walkman NW-A3000 MP3 Player Logo
555 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
