Question about No Brand Botta Watch - Uno 24 - White
UNO watch battery replacement
Does run
  • Bill Feb 12, 2012
    Correction: DOES NOT RUN !!!!
    How to open the Solo UNO case to replace battery ??
Timing marks ON FIAT UNO 1400
you can get help from service and repair manual which will guide you to fix the problem and with diagram and to get the manual go to the given link http://toolsnyou.com/
Jun 22, 2014 | 1994 Fiat Uno
I have a Fiat uno Pacer 1400 sx, the car just cuts out while driving, i replaced the fuel pump, did not cut out but the fuel pump is leaking oil, what could be the problem now?
hi there i have uno pacer 1400 sx model. I drive my car a for a few km and then it cuts i cannot start it till it has cooled off. the swings but does not start. what can the problem be.
Mar 28, 2012 | Cars & Trucks
I'm diving Uno Pacer, there is no spark from coil
Replacing module can assist a lot. I prefer changing spark plugs and cables in addition.
Jan 20, 2012 | 1994 Fiat Uno
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
I have uno attack the game but i lost the instructions so i dont know what the cards mean. can u help
The object of the game is the same as the original Uno game with an unpredictable twist. Players still need to get rid of all playing cards before other opponents and reach 500 points and you still must scream "Uno" when you have only one card left. But this Uno has an extra twist. Instead of picking a card when you have nothing that matches the discard pile, you must press the fire button that disperses none, one or many cards when pressed. Read on to learn more.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions
    Starting the Game
  1. Step 1 Get a pad of paper, pencil and calculator handy to keep score. The winner is crowned when they reach 500 hundred points. Have winners after every round for younger players, the scoring math will take too long and they will lose interest.
  2. Step 2 Remove all contents from the Uno Attack box and lay out on the table. Unscrew the battery cover with a Phillips screwdriver and place 3 C size batteries to the slot. Reattach the cover and press the button to check if the batteries were put in correctly. It should make a buzzing noise if correctly installed.
  3. Step 3 Combine the top part and the bottom part of the Launcher by pushing the red top onto the purple base in an angle, with the exiting slot facing the same way as the UNO fire button on the base. Listen for the snap as it connects.
  4. Step 4 Decide on the dealer by choosing cards from the deck. Highest numbered card gets to deal first and then the deal goes around clockwise. If you pick a command card, it counts as a zero. The player to the left of the dealer gets to discard first.
  5. Step 5 Shuffle cards and pass out 7 to each player. Place the rest of the cards into the launcher, and use the top card from the launcher as the first card in the discard pile. The person to the dealers left must follow the directions of the command card if it happens to be picked.
    Playing
  6. Step 1 Match the color or the number of the top card in the discard pile when it is your turn. Place your matching card on the top of the pile. Save command cards till your opponents are low on cards unless you don't have any cards that match the discard pile. This practice is a good strategy but can fail miserably because command cards left in your hand at the end of each round are more points for that rounds winner.
  7. Step 2 Choose to save a playable card for later in the game and take your chances by hitting the Uno fire button instead. This is called reneging.
  8. Step 3 Follow the directions of special card. If you do not have what it is asking for then you must press the Uno button on the Launcher. Most cards are like original Uno or self descriptive.
  9. Step 4 Say "Uno" loud enough that all players can hear as soon as you have one card left in your hand.
  10. Step 5 Call out "Uno" only after another player lays their second to last card on the discard pile but before the next person takes their turn and that player must hit the Uno fire button twice. You can go out with any card including a command card except the Trade Hands Card.
  11. Step 6 Add the cards left in the losers hands at then end of each round, this will be the winners score. Each face card through 9 is scored by its value. "Reverse," "Skip" and "Hit 2" are each worth 20 points.
Hope it helps you.......... do not forget to rate me on FIXYA :)
Jul 28, 2010 | Mattel Uno Attack! Card Game
How to set the clock how do i no the battery good just got it
If the watch is not running it's probably the battery. To set, pull the crown out and turn to adjust the time. Push the crown in to run the watch. If the watch is new the battery should be OK but take it back to the store if it doesn't run. If you bought it used take it to any watch shop for a battery replacement. Sears does it for about $8 or less.
Apr 28, 2010 | Movado 0604771 Wrist Watch
The watch is not running after replacing the battery, the stop watch part is running.
It could be that the battery has a poor contact. Try cleaning the battery with surgical spirit and avoid handling its faces.(hold the edges).
Clean also the watch contacts.
Feb 03, 2010 | ESQ 07300902 Wrist Watch
Uno Extreme
Mattel game instructions can be found here: http://www.mattelgames.com/demo_rules.asp
Apr 11, 2009 | Mattel Original Uno House Rules
Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Mar 01, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
No Brand Botta Watch - Uno 24 - White Logo
129 people viewed this question
Top No Brand Games Experts
Pamela Leach
Pamela Leach
Camryn Johnson
Camryn Johnson
Level 1 Expert
Are you a No Brand Game Expert? Answer questions, earn points and help others
