Question about GE XL1800 1100 Watts Microwave Oven
Turn table table no longer rotates-is that an easy fix?
  • CharlieGjr Nov 10, 2008
    I'm told the turntable fix is simple & the part costs under $40, yet no one will say how to do it. A service call quote to come to my mountain home is $120 --before we even get to fixing the problem. If this is simple, please give up the answer.
  • GE Master
  • 19,396 Answers
See the following suggestions from Repairclinic:
The carousel won't turnAlthough the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it. So we recommend that you seek the assistance of a qualified appliance repair technician. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
Posted on Oct 24, 2008
The rotating plate in my microwave no longer turns...
You need a new turn table motor part # WB26X10038
Order from Bi Coastal Appliance Parts @ 1 800 673 1262
Aug 18, 2011 | GE JVM1870 Microwave Oven
Turn table no longer rotates
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 28, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
My daughter just moved into a townhouse and the microwave plate warms, however the plate doesn't rotate. Is there any easy way of fixing this issue
The rotating table in a microwave shouldn't be getting warm unless something is sitting on it and transferring heat to it. The chamber should not be left empty when the microwave is running. The motor that drives the table is of very low mechanical power but should be able to handle about any load it must. I suggest you remove the glass table, the ring on which it rides, put a cup of water in the chamber and turn it on. Look at the drive spindle that engages with the table when installed. If it isn't rotating 9should be easy to see) then the motor is defective which is highly unusual to see one fail. If the spindle is clearly not moving, then I recommend replacing the whole unit since while the part isn't expensive, the labor cost would likely make the repair uneconomical.
Dec 22, 2010 | GE Microwave Ovens
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
My food no longer rotates while cooking,and it makes a clicking noise.
this is usually a bad turn table motor. if you remove the screws out of the bottom of the otr(over the range) it will hinge down and back and you will see the motor in the middle of the otr. your local parts house should have this item in stock or be able to order it for you
Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
Plate will not rotate
Yes there is a small gear reduction type motor that drives the turn table. The motor can be replaced.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave rotating assembly jumps up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Dec 21, 2008 | Microwave Ovens
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Sharp Microwave turn table turning irregualrly
You can see and hear a YouTube video of how a turntable motor should sound when you rotate it by hand.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can probably find an exploded view and order parts by entering your model number here: http://www.searspartsdirect.com
Sharp parts are usually less expensive when ordered from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Microwave Ovens
GE XL1800 1100 Watts Microwave Oven Logo
157 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
