Question about Maytag Washing Machines
Maytag MAV2755AWW makes a horrible noise during wash/spin cycle
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
appldoctom
  • 311 Answers
SOURCE: Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Posted on Jan 03, 2009
SOURCE: maytag pavt234aww
I had to replace the pump assembly, the pulley has a bushing in it that was working its way out and rubbing against the base plate of the machine.
Posted on Feb 14, 2009
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
My washer is making a horrible noise when it goes into the spin cycle. It sounds like it is about to explode.
The bearings on those washers go bad and the washer gets very loud during the spin cycle. It probably won't explode but for what it might cost to fix it you might want to blow it up yourself
Jul 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer makes a horrible noise in the wash and rinse cycle but not in spin
Sounds like it could be a loose or stretched belt if sharp squeal hard to tell without noise description.
Jan 14, 2010 | Maytag Washing Machines
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Sep 01, 2009 | Maytag Washing Machines
Does not wash
not sure about the model maybe the belt or motor coupling .look under the bottom and check it out
Apr 07, 2009 | Maytag MAV2755A Top Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Something tumbling around during spin cycle
Yes, a coin can get down into your tub and make a horrible sound during the spin cycle. It has happened to me before. So have your washer checked out.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
