Question about Mitsubishi WD-73638 DLP TV
I am trying to connect my hp laptop to my '73mitsubushi tv with an HDMI cable. TV says wrong format. Help!
Trying to hook HP laptop to TV using HDMI cable
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
You have to select the monitor out on the computer is ether the f1 or f2 key on the laptop
Posted on Feb 12, 2012
3 Suggested Answers
zecs
  • 123 Answers
SOURCE: Trying to hook up HP DV6000 laptop to Mits 55859.
heat vga chip
Posted on Jul 13, 2010
toyladi3
  • 597 Answers
SOURCE: trying to hook up an
There is no special setup to make it work or ask the computer to send a signal. All you have to do is for you to hook up the VGA cable to the the port that is on the television, then you select your AV channel and you will have your computers display on the television.
From your remote just select through your AV channel and you will see the channel that the computers display will come up on.
Take care and good luck
Hope this helps!
Posted on Dec 14, 2010
How do I hook my HP Pavilion Notebook up to this television?
You can connect via HDMI > HDMI if both have one, or VGA to VGA, VGA > HDMI all leads available on eBay. go to source and choose VGA option.
May 17, 2015 | Sansui 19 in. LCD TV
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
How do i hook up my hp dv6500 LT to my hdtv?
for connectin it to TV u need a cable for it. like say HDMI cable. It comes very costly. and u should be havin a LCD tv..
Sep 03, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Having a problem connecting HP G50 laptop to TV
You will have to select the input for this connection.
Sep 03, 2009 | Panasonic TH-50PX75U Plasma HDTV
Hooking up sony tv to HP laptop
Do you have a HDMI jack on your TV? it looks just like the blue/graphics/monitor jack on your laptop. If so use it to connect and you should be able to use your tv as a monitor. (if you tv came with the HDMI cable?, if not you can purchase one ez enough from Radio Shack)
Check your users manual for directions on how to use the remote to get it to that function. My Hansphree TV I have to put it on AUX to use my laptop hooked to it and see my TV as my lappy monitor.
Hope this helps you and others! Good Luck.
Feb 17, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Jan 28, 2009 | HP Pavilion dv6000z Notebook
How to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Jan 16, 2009 | HP Pavilion dv6000z Notebook
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Mitsubishi WD-73638 DLP TV Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
