Question about Ridgid Saws
Miter saw laser adjustment for 12 - Ridgid Saws
    Genius:
  • 1,212 Answers
Depending which model you have, the laser is part of the saw blade stabilizer and is not adjustable beyond removing debris between the stabilizer and the blade.
If the saw is not cutting square to the fence, that is a different adjustment. Rather set of adjustments. The procedure is outlined for your specific saw in it's respective owners manual. You can download here:
http://www.ridgid.com/Tools/Literature-Search You may need to enter the search criterria, but simply "Miter Saw" is adequate.
Posted on Feb 15, 2012
  • 37 Answers
SOURCE: The delta universal miter saw stand will not adjust to level posi
Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: Craftsman 12 in. Compound Miter Saw w/Laser Trac stopped working
If you can provide the model number I can do some research. It could be quite a few things that went wrong. If you are comfortable in troubleshooting the tool let me know when you get it back and I will try and help
Posted on Jan 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: 12 inch miter saw blade turns slowly and doesn't
There's no debris or wood jammed in the housing around the blade, is there? Try unplugging and removing the blade, to make sure some wood hasn't gotten wedged in there somewhere.
Otherwise, make sure the blade is on tight. If so, there is likely a problem with the motor itself.
If it's still under warranty, I'd contact Ridgid at this link: http://www.ridgid.com/Tools/Support/
Otherwise, they have a tools forum where you might be more likely to find someone who's experienced a similar problem.
Being reconditioned, it sounds suspect to me...
Sorry I couldn't be any more helpful...
Posted on Mar 26, 2009
  • 33 Answers
SOURCE: My blade gaurd will not automatically rotate out
MS12502 has a solid arm actuation to move the blade guard, this is either bent, broken, unattached or otherwise not functional. sometimes the moving parts get full of sawdust and a major cleaning is all thats needed. generally all woodworking tools should be blown out with air after each use or end of day.
actual model number of your saw would be more helpful.
Posted on Dec 02, 2009
al_kupchella
  • 843 Answers
SOURCE: New Dewalt 745 saw, blade not parallel with Miter slot
Either take it back, or take it apart and make the holes bigger. For that kind of money, you should be able to adjust it dead-on. I thought I had the same problem on an old Craftsman, but I found that I just hadn't loosened things up enough. It's hard to see how much wiggle room you really have under the washers. And if there are aluminum castings involved, there can be a burr raised by the initial setting that it gets stuck on.
Posted on Jan 19, 2010
The laser stopped working on my Hitachi C12LSH miter saw. Now I need to determine whether the laser burned out or if there is another problem. I need to know if the laser works on 120 volts so I can t
clean laser and wire, also clean circuit board and heat circuit board wit the heat gun. if it will not work please relapsed laser. laser not work on 120 volts. laser work DC volts.
Oct 21, 2014 | Hitachi 12" Sliding Dual Compound Miter...
Adjust laser on 12" miter saw
Use laser adjuster vise grips and set it with crazy glue .
Aug 05, 2013 | Kitchen Appliances - Others
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
My sliding laser miter saw is about 1 degree off on 90 degrees cuts, how do youadjust it?
Adjust the angle by turning the bed of the saw bit by bit until you have a 90 degree cut on a piece of timber measured with a carpenters square. Some saws have an adjustable pointer and you can now adjust it to point to 90 degrees. If the bevel cut is off, the vertical downwards cut, there may be grub screw at the back of the saw which will allow you to make adjustments.
Jul 04, 2011 | Ryobi 10 In Miter Saw With Laser
Changing the blase on a craftsman miter saw, model nimber 315.212240
my miter saw has stopped working. i have checked the plug and electrical connection. it worked without problems 2 days ago. it gave no warning of problems. is there "a built in" fuse or circuit breaker?
Oct 07, 2010 | Craftsman 12 In Miter Saw With Laser Trac...
I have a 12'' milwaukee miter saw with a digital fine adjust,but the digital readout is not correct. how do i fix it?
Hi, I have the exact same problem! I'm gonna jump onboard - is there any way to re-adjust the digital readout, anyone?
Jan 22, 2010 | Milwaukee 6950-20 12-inch Dual Bevel Miter...
How do you adjust the saws angle cut? When it is sett at 0 degress it is not making a square cut.
take a framing square sit it on base plate and adjust till its square and level with that angle.works same with table saws also hope that helps ya
Nov 28, 2009 | Hitachi C12LSH 12" Sliding Dual Compound...
12'' Ryobi miter saw with loose blade
You may need to use lock tight on the threads. Also replace the standard washer with a lock washer if possible.
Mar 12, 2009 | Saws
Craftman miter saw
should be located at the pivot arm assy where close to the motor.
Mar 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
199 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
