Resin band is connected to timepiece with screw head on both ends. Need not only something to secure timepiece but also screw drivers.
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
SOURCE: change casio g shock resin watch band
It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
make sure you keep all original parts in case of toruble
Post a photo if you can after the change will be nice to see the change
Tom
SOURCE: How do I install my replacement band (resin) on my Casio OC500?
there is a special tool but a small penknife can do the job look where the strap end meets the watch push the edge with your nail you will see the spring bar there press it in with the knife it should come out . be careful it dosent fly off and maind your eyes then put the bar in the new strap put 1 pin in the hole hold with thumb and index line it u and depress the spring and line up and release. hope this helps joe
SOURCE: Lost screw to secure watch band on Skagen 355LGSC
You just have to to see the watchmaker. As all watch band screws are made to particular bracelet, it's allmost impossible to find the right one if you are not in watch repair business. It will not cost too much and will save your time and nerves if you'll ask the watchmaker.
Find your nearest watchmaker and ask for help.
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Testimonial: "THANK YOU"
