Question about S&S Worldwide S and S Worldwide Ultimate Collage Bulk Easy Pack
Wiring diagram for a spa-tech hot tub to install an easy pak control system
Why won't the spa turn on?
The best way to detect where your problem may be is by testing each unit associated with your hot tub. Start by turning off the main power, now unplug all the accessories on your power pak
  • pumps
  • blowers
  • lights
  • ozonators
  • radio
something is tripping your power pak and this is the quickest way to find out. Turn the main power back on. Plug in each accessory pausing between, when the pak trips you know you have found your issue. It could be as easy as a fuse or a ceased pump.
Once you find out what needs to be repaired you may want to call out a hot tub service professional to repair the unit. Hot Tub Power Pak Repair
Jul 27, 2015 | Pool & Spa
Balboa spa user manual
Unless it's a 110 tub, you don't. If the system is designed to run on 220 the circ pump and flow pump will not function properly, the power pack may not function and the tub will never reach temp. If it is a 110 hot tub I would still suggest having a licensed electrician run the line for you. Most insurance companies will not cover any type of hot tub related claim unless installed by licensed tub tech/electrician. If you insist on wiring it yourself, the BLACK wire is the "hot" wire carrying the current. In 220 installations the RED wire is the second "hot" wire. The WHITE/GREY is the neutral wire, and the GREEN is the ground. But again, I STRONGLY recommend paying the $80-$95 bucks to have it done professionally. I hope this helps =)
Nov 03, 2013 | Pool & Spa
I have a density riverspas hot tub and it is stuck in sleep mode and there for won't heat up how do I take my density riverspas hot tub out of sleep mode
Difficult to answer without knowing the "Brand" of your Spa Support Pak System. Lets presume you have the most common basic pak available - Balboa.
Press "Temp" button and then immediately press "Light". You will then sequence between 3 modes:
  • Economy - may display as Ec
  • Standard - may display as Std or St
  • Sleep - may display as Sl
Should save last setting
Dec 03, 2012 | Pool & Spa
Wiring motor hot tub
The wiring diagram should show on side of motor.
Here is basic motor wiring:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Test each lead as shown in following image. In the case of 240Volt, the 2nd wire is not Neutral, but testing is same.
http://waterheatertimer.org/images/Motor-capacitor2-800.jpg
If you have 2 speed motor, then you will have switch or timer controlling the speed:
http://waterheatertimer.org/images/GM40-wiring-2-speed-pump-400.jpg
Oct 05, 2012 | Waterway 5 Hp 230 Volt 2 Speed Side...
QCA Spa Contol Panel Issues
Flow issues can be frustrating, check each of the following
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter. (Try run system w/o Filter)
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
If none of those help try this. There is a link to s Balboa site for service tech diagnostic help. There are step by step instructions for diagnostics.
Jan 23, 2012 | Pool & Spa
Won't heat
it's very easy to install if you disconnect one wire at a time from the old one and immediately install it on the new one. I recommend taking a digital photo of the old board before you disconnect anything to have a reference in case something goes awry.
Apr 07, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub wiring
this has nothing to do with computer speakers. it is a hot tub wiring problem...
Jun 22, 2008 | Audio Players & Recorders
S&S Worldwide S and S Worldwide Ultimate Collage Bulk Easy Pack Logo
174 people viewed this question
Top S&S Worldwide Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a S&S Worldwide Toy Expert? Answer questions, earn points and help others
