Question about Video Game Consoles & Games
In My Ruby super system I need to change credit card running from phone line to internet dsl line ,
I would like to know how can I change the credit card processing from phone line to dsl internet line, cause it is having problem when run on phone line , can any one help ??????
SOURCE: need for DSL filters with DECT 6.0?
Yes - you need the DSL filter in jack you plan to use (you need them in any jack with a phone/fax connection. It matters not that the handset is cordless - the connection to the wall needs the filter or your DSL will a) not work or b) work poorly
Posted on Sep 07, 2008
  • 1214 Answers
SOURCE: Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Posted on Jan 24, 2009
  • 514 Answers
SOURCE: Unable to hang up phone. The line is busy/can't make/receive call
sounds like you need a DSL filter, go to page 41 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Posted on Feb 22, 2009
  • 3 Answers
SOURCE: Modem won't connect to internet.
maybe you have to wait for your provider for them to isolate the problem, it seems that your modem got hit maybe by high surge. ask them to bring a spare modem for isolation.. there is no way for you to isolate the problem coz you've already done the basic....
Posted on Jun 20, 2009
MUKHTAR
  • 2017 Answers
SOURCE: I have a brother MFC-7430 all-in-one - Fax won't work
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Hope this helps. Please rate my response.
Thanks.
Posted on Mar 16, 2010
Acostomer swap his credit card tow times and the Sestime shut down I see on the screan Gemix(tm)virsion v2.6.19
"a customer swiped his credit card two times and the system shut down,now you see on the screen gemix(tm)version v2.6.19",,,,,
there is nothing you can do on your end,your boss will HAVE to call verifone ,they are in control of your equipment,again,there is nothing you can do,you need your boss to call verifone.
the ruby system is owned by your boss but servised by verifone only.
Apr 21, 2015 | Computers & Internet
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a second line for dial up and would like to switch over to dsl through my cable company to save some money can I drop my second line (dial up) and go to cable without any problems. I pay MSN direct...
DSL connection works on the same line provided by company who provides DSL. If dialup line is not provided by DSL company, you can drop dialup line and contact DSL company for DSL connection. If dialup line is provided by DSL company, migrate your internet plan from dialup to DSL by contacting DSL company.
May 30, 2010 | Computers & Internet
One line is always in use
First, do you have DSL on the third line? If the DSL is on that line you need to check the line for filters. Make sure there is a filter on the main line out from the DSL modem.
Next check your fax machine, credit card machine, alarm, computers and anything else you may have on that line. Any of these devices may be keeping the line off hook.
Now remove all of the phones and try to get one working. You may have a shorted line in the phone room or a pinched wire. Replace any wire you can to see if you can get one phone working. If you can't get one working then you should call a technician to check the phone room.
If you get one working then add the second and so on, testing everything each time you add one.
May 21, 2010 | NorStar T7316E Corded Phone
Intercom / page problem with AT&T phones model 944 and 955
Do you have DSL on this line? Make sure you have filters on the lines going to the phones or take the line coming out of your DSL modem and split it to the phones.
Also, try unplugging your fax, computer modem or credit card machine and test the intercom. Sharing one line for several devices can make the intercom unhappy.
Feb 21, 2010 | AT&T 944 Four Line Intercom Phone
Can the microsoft MN700 Router be used with cable internet instead of DSL from the phone company?I switched from Verizon DSL to Comcast Cable internet but can not find an answer if the MN700 is compatible...
I would say yes but i have not tested it personaly, but what i know about routers it should work with. Cable internet and dsl are exactly the same thing. The only difference is how its delivered to your house and the speed of it.
DSL tands for "Digital Subscriber Line." It is medium for transferring data over regular phone lines and can be used to connect to the Internet
cable the same thing except it is internet though the cable line. you u run the out of your
you probably wont even have to change any settings on it either. the line out of the back of your cable modem will plug into the same spot the old cable ran to when you just had dsl.
if this has been helpful please mark it has fixya. also please rate me, and if you have found it very helpful or informative please recommend me.
Nov 16, 2009 | Microsoft MN-700 Wireless Router
Phones will not release hold when picking up on a different phone
Make sure you have filters on the lines between your DSL and your phones. Use the line out from the back of your modem to split to your phones if you don't have any filters. You may have to take line 2 from the back of the DSL modem to send to all of the phones. This is usually a filtered source and should isolate your phones from the DSL. Put the filter on any other devices that are sharing line 2 too, fax, computer, credit card machine etc.
Jan 19, 2009 | AT&T 944 Four Line Intercom Phone
COMM ERROR on Verifone 3750
This could be a number of things.
#1 do you have DSL internet service? If so do you have a DSL filter between the jack and your terminal?
#2 Do you have digital phone service? Vontage or Comcast will cause this problem . Especially upon batching out the terminal.
#3 Check the blind dial setting within the other setup option. This option is buried, so it will require a phone call to Merchant service Provider.
If none of these work, then it is time for a new service. Place a call the Heartland Payment Systems Credit Card Processing and change your card service provider. The only card service provider that has a merchant bill of rights and field service techs (for free).
Nov 17, 2008 | VeriFone (M19755014US1) Magnetic Card...
Accepting credit cards with an internet connection
I have to change my account with my credit card company.
Jul 12, 2008 | VeriFone Omni 3700
Plugging it in
Your Nortel M7208 phone is plugged into your Norstar phone system (not the phone line) You would not be able to use DSL on the same phone port used by the M7208 phone. A filter connected to that port would not solve a DSL issue and could only cause problems with the M7208 phone. You may need to put the filter on the phone lines before they connect to the Nortel phone system... I don't know which system you have or how it is wired up so I am not sure how easy that would be for you.
Nov 10, 2007 | NorStar M7208 Corded Phone
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
