Question about Toshiba Computers & Internet
My fujitsu laptop doesnt start
My laptop is fujitsu and I cant start it anymore. I have it since last year. When I try to start it the lights come up but the screen doesnt show anything... I am really worried. What could the problem be???? Thank you
  • cuevaslizzie
    cuevaslizzie Feb 12, 2012
    Please any suggestions are welcome in french English or spanish it doesnt matter
  • cuevaslizzie
    cuevaslizzie Feb 13, 2012
    Thank you Chris for your solution, but I dont think is the back light because it doesn't flashes on and off. The hue is fine, the colors have always been ok. The problem is that sometimes it freezes when I am doing something, I turn it off and then I cant start it anymore. I can hear it trying to start but then it comes off again. It had happened before and all I do is to try, try and try and eventually it works, but today seems that doesnt work..... What do you think the problem could be? Once again thank you for your answer
  • Toshiba Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Feb 13, 2012
  • Chris Hingee
    Chris Hingee Feb 13, 2012
    When the CPU overheats then it will shut down (i.e. thermal overload) or freeze and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
    A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
    Check the CPU fan to see if it spins freely, if not replace the fan.
    If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a can of compressed air to do this.
i used martha pavolko laptop to read my mail and now i cant log off so she can use her laptop she cant go to her fb page to play her games
Dec 08, 2013 | Fujitsu Siemens Computers & Internet
Pls help my compaq presario wont start up anymore.. after i put my laptop to sleep mode when i try to wake up or hit anybutton it doesnt wake up..then i press hold power button to force shut down,then i...
Hi
this may work for you
start up pressing the F8 key along with the power up key
then if it goes into repair optionstry the last known good configuration option
windows should then restart and try to go back to when all was good
hope this has helped you
if it has please let us know
so that we may be able to help others
many thanks
Jul 18, 2011 | Compaq Computers & Internet
Fujitsu st5112 tablet was working fine then unplugged to go out - and gone. No power, won't boot, black screen. Battery indicator lights when battery removed / replaced, AC light comes on when plugged in...
Try to hit the f8 button after pushing the power button to see if you get a menu. If you do, it will ask you about starting in safe mode, staring in last know good configuration. If you can start in last known good configuration, that will get you back to the last time the computer worked properly.
If that does not work. Remove all power from the laptop for about 10 minutes and try to start it.
Try these ideas and let me know how you do. I stand ready to assist you further.
Brian
Feb 01, 2011 | Fujitsu Stylistic ST5112 Tablet PC
I have an Advent 7204 laptop two years old and suddenly it doesnt work anymore. When turning on, the lights which flash on went all the way through as normal then suddenly started fading and the machine...
I would suggest you to check with a different adapter, first.
You don't have to buy a new adapter for that.
Try to borrow from someone who has a compatible adapter.
Mar 13, 2017 | Dell Latitude D600 Notebook
Bettery can't charge
you may have the wrong type of charge, your port where your charge cord go in may be loose or not connected correctly anymore.
You also may want to check into buying a new battery for that laptop. Depending on how old it is it may of died after alot of use.
I'd test it using those two ideas first. If that doesnt work contact the maker of the laptop.
May 05, 2010 | Fujitsu Siemens Computers & Internet
I cant get my fujitsu amilo li 2727 to turn on, it was working yesterday but now i just get the light indicating its turned on, but nothing else happen, ive tried taking the battery out and trying to...
please check if moisture level in the place were pc was left wasn't too high for it to operate. then please check are memo banks not loose, baisically just remove them, swap spaces and reinsert to another slot. some cases fault is just loose memory.
Nov 03, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
I have a Toshiba Satellite A305D-S6848. Last
Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons (or those appropiate to your model) to send the video signal out to the external monitor. If you do not get any image on the external monitor it means that most probably the mainboard is damaged (video card or even more). Expensive to fix or replace. Have it checked by a professional.
Oct 06, 2009 | Toshiba Satellite A305D-S6848 Notebook
Fujitsu siemens amilo pro v200 problem!
this could be a corrupt usb controller or web cam driver; but before we get too deep when it is booting up press F8 and you will get a menu, one of which will say, start windows with 'last known good configuration', highlight line the press enter for a restart. If no luck with boot up come back.
Jan 15, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
