Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
The camera powers up, shutter does not open and you can not take photos. you can switch to view mode and see pictures fine. Help!
  • proffer109 Nov 27, 2008
    any new tips? my camera is fully charged and has all other functions.. just the lens will not open so i can take video or picture... everything else is perfect though... help any advice?
  • 10,594 Answers
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Posted on Oct 24, 2008
  • Shahid Electronics
    Shahid Electronics Oct 24, 2008
    I'm sorry, above free repair scheme is for S400 camera........Not for SD400
No view though the lens
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 26, 2009 | Canon PowerShot S2 IS Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
May 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Will not turn on
Sounds like your lens is stuck. Try a gentle tug and it should open all the way. Then you can power your camera down.
Nov 01, 2007 | Samsung Digimax S800 Digital Camera
Camera won't turn on/lens extended
General system failure- Contact Samsung for repair cost.
Aug 30, 2007 | Samsung Digimax S500 Digital Camera
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
LCD screen won't turn on and shutter won't open or expand.
It's probably in PC mode. It still thinks that it's connected to the computer via the USB. It should be somewhere in the set up configuration. If you can't get it to switch back to normal, disconnect it from all power sources(including internal memory button battery if present) in order to reset it. make sure you turn off the camera before disconnecting it from the USB. Good luck
May 30, 2006 | Casio Exilim Pro EX-P600 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
146 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
