Question about White Rodgers Home Security
How to set a 5A75-12 White-Rodgers
How to set a fan and limit switch
2 Suggested Answers
liteswink
  • 99 Answers
SOURCE: thermostadt not activating for fan or air
please contact the techline 18002842925.
Posted on Aug 02, 2010
Does white Rogers thermostat 1f56n-444 have a reset button
White Rodgers 1F56N-444 User's Manual - ManualAgent
www.manualagent.com > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Aug 04, 2015 | Home Security
I don't want to program the 1f85-275 thermostat, i will adjust when needed
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
Nov 15, 2012 | White Rodgers White-Rodgers 1F85RF-275...
I have a w-r themostat and i can not turn the fan off. the ac is off and the thremo is off but the fan keeps running. how do i turnit off.
If you open the bottom swing door you will see a switch on the left that says Fan On/Auto. Make sure it is in the Auto position and the fan should cycle on and off with the equipment.
Tim Burke, White Rodgers Employee
Email me with further questions at tim.burke@emerson.com
Aug 19, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have a White-Rodgers 1F80-51. The fan blows
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
May 31, 2010 | Heating & Cooling
On my white rodgers thermostat 1F80-361 air and heat wont work
Mine is doing the same thing!! My daughter and I are FREEZING!!!
May 23, 2010 | Heating & Cooling
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Home Security Logo
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
