Question about Yamaha V Star 1100 Classic Water Sport
How to timing a yamaha waverunner vx1100
I set the timing but will not start how do i set the cams
3 Suggested Answers
finish line
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
SOURCE: I have a 2003 yamaha 700 waverunner. It starts
sounds like the impeller is knackered, check the impeller housing and the impeller itself, impeller should look like its nearly touching the housing, check the housing to see if it has created a grove, if they both look worn, replace with new
Posted on Oct 07, 2011
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
I have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Sep 29, 2009 | Boating
How do I reset the code on a yamaha waverunner
How do I reset the code on dash board 99 yamaha waverunner 800?
Aug 02, 2009 | Sport & Outdoor - Others
Waverunner sat for 4 months. thought battery was
Try jumping the waverunner using a set of jumper cables and your vehicle, this will rule out if the battery is bad. If you still have the same issue, check the connections. The connection at the starter or another place may have corroded a bit. Yet another option is to remove your spark plugs to make sure that your motor has not hydraulically locked. Once you have removed the plugs try and turn over the engine. You may need to ground out your plug wires if you have an electronic ignition to protect it. I hope this helps.
Jul 13, 2009 | Sport & Outdoor - Others
May 15, 2009 | Yamaha 12V Air Pump
Water Sport Logo
325 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
