Question about Bush Industries IDLCD26TV16HD LCD TV
Looking for circiut digram for bush lcd 26tv16hd power mlt666a
Power low 12vot rail req cct diagram no sound or picture or front on/off led 12volt is aprox 5 volts
  • 430 Answers
Samsung un60d6000 tv no picture only sound?
the voltage is ok doo you have constantly 150 v if not led blocks is bad
Feb 28, 2017 | Samsung UN60D6000 60 Inch 1080p Smart TV...
Power supply fault?
Check all electrolitic capacitors at power supply area : better replace them.
Apr 15, 2008 | Bush 2871NTX 28" TV
I have an LG 55lm4700 that has no power led and no picture, wondering what might be the issue.
it sounds like a blown capacitor in the unit somewhere.
here are some tools you are going to have to have: ohm meter,oscilloscope, signal generator, soldering equipment,
grounding equipment, diagrams, schematics, test points, layout of circuits,
Sep 18, 2015 | LG 55-Inch LED LCD TV - 55LM4700 Cinema 3D...
LG 42LD560 LCD TV POWER PROBLEM
While you checked the condensers, did you look for faulty connections? places where the solder has a little crack?
And did you check visually, or did you check electronically? In a power supply lots of things can go wrong. More than alone a capacitor with a rounded head.
Jul 11, 2014 | LG 42LG30 42 in. LCD HDTV
Bush led 26916hd
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Bush LCD/ Plasma/ LED Pivot Mount in Black
My tv no longer turns on its a LCD26TV016HD
Is this TV made by Bush, model LCD26TV016HD?
It may ahve bad power supply module, http://www.chsinteractive.co.uk/electrical-components/misc/lcd26tv016hd-pcb-psu-bush-mlt666a.htm
That will be the first place to look, look for blown fuse, bad caps, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Mar 18, 2011 | Televison & Video
It's a Kenwood VR-4080 the reciever turns on and works but has very low volume and amp sinks get hot reguardless of volume setting?
heat in amps =power or fault, since you have no power then its most likely the fault that is causing the heat, I would take it to my dealer or a good tech. Modern amps like these are very complicated, almost impossible to diagnose and repair without cct diagrams and service info. They also have potentially dangerous DC power rails.
Hope this helps
Thanks for using FixYa
Aug 13, 2010 | Kenwood VR-4080B Receiver
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
May 28, 2009 | Philips 107E61 17" CRT Monitor
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Bush Industries IDLCD26TV16HD LCD TV Logo
221 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
