Question about Candy Washing Machines
Candy grand o go482/2-80 very noisy when spinning
After some research I think it's the bearings gone on my machine but after checking every washing machine spares website I can find I still can't find a part. Does anyone know if it is even possible to replace the bearings on this model or do I need a new machine?
  • naomiandd16
    naomiandd16 Feb 12, 2012
    I've looked into Candy coming out to look at the machine and it will cost 300 pounds : / I may as well get a new machine.
    Scholar:
  • 58 Answers
The manufacturer, "Candy Products" http://www.candy-domestic.co.uk/about_us/Default.aspx is more likely to provide an authoritative answer than anyone else. They seem to manufacture their own machines, answers based on experience with other makes and models are of no value to you in regard to this question.
the foregoing aside, what one man has made, another man can also make, or repair. It is extremely unlikely that Candy paid to have an exotic one of a kind bearing made for this washer. However, even if the bearings are a common industrial part, that doesn't mean that removing and replacing them is easy or cost efective, or even the cause of the noise.
Unless you have more expertise than your question implies, perhaps you should ask to have a Candy repairman diagnose the noise and if your diagnosis is confirmed give you seperate prices for the bearings and the installation of same. From that you can discern how long the professional repairman familar with the machine would require to do the work, and you should double or triple it to estimate how long it will take someone unfaniliar with the machine to do it
Posted on Feb 12, 2012
5 Suggested Answers
  • 942 Answers
SOURCE: Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Posted on Jul 14, 2009
kevin_getz
  • 1031 Answers
SOURCE: i bought a candy go482 4 weeks ago.it is leaking
Depends on where it's coming from. One thing you can check are the water inlet hoses. If they're not on tight enough, or the threads are crossed and there isn't a seal, water can run down the back, and through any openings on the back panel onto the floor. Another possibility is there's a leak from the drain pump, or the hose connecting the tub to the drain pump. Your best bet is: CONTACT THE MANUFACTURER!! It is brand-new and under warranty.
Posted on Dec 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: We have just purchased a GO482 Candy washing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
  • 6277 Answers
SOURCE: candy grand 0 282/1-80 door lock not working
If you are saying that the door will not lock there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If the door is not unlocking at the end of the cycle I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 24, 2011
Washer will not spin, it makes noise as if bearings have gone, empties ok and washes ok
Hi if your beko washing machine is causing a problem and wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
May 03, 2014 | Beko Washing Machines
The drum is making a noise
The bearings may have failed or the spider might be broken. Spares should be available and can be replaced.
Dec 28, 2012 | Washing Machines
My hot point wma bearing is gone. Where to buy spare ones.
Depends where you live here in England I buy from hotpoint.however its quite a big job to do also you may find this models bearings are sold on as half drum,you need to buy he half drum with bearings fitted to replace and costs parts approx 70.pounds..hope this helps
Jul 01, 2012 | Washing Machines
My whirlpool washing machine problem is the bearing,so do you think how much it cost me if I will buy a new bearing?
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares, software, installation instructions or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Sep 07, 2011 | Washing Machines
Have a kleenmaid front loader washing machine KLF 1600;it needs a bearing kit[2 bearings & seal]???for main drum and also a belt MIG OPTIBELT 6EPJ1260 code 111622 or GATES 6EPJ 1260 code...
FixYa is sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
John C.
Jul 11, 2011 | Washing Machines
There seems to be something retarding the spinning of the tub and it sounds like there are rocks being washed. It doesn't spin enough of the water out of the clothes so that they have to be wrung out...
sounds like the main bearings have gone or the motor bearings not sure how you describe noise. is the drum nice and smooth while you turn it by hand if it feels rough it will probly be bearings this will be slowing machine i think you will have to look a bit further inside good luck
Jun 07, 2011 | Frigidaire Washing Machines
Noisy drum bearing also play on drum
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Apr 30, 2011 | Washing Machines
I have a John Lewis JLWM1203 washing machine but understand it was an Electolux made by possibly Siemens. 2008 year. 1. What is the correct model/make for spares. 2. The drum is hammering on spin cycle or...
If you haven't done already, I would be tempted to look for spares suppliers with the info you already have i.e. JLWM1203! Do you have a manual with anything in it?
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
If this has assisted you please score accordingly.
John C.
Apr 11, 2011 | Electrolux Washing Machines
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
521 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
