Question about Refrigerators
Samsung refrigerator RF267ABRS French Door water dispenser not working
Ice water dispenser, sometimes it works,sometimes it does'nt work. Filter is not clogged, lines are not clogged and water is hooked up correctley. Does anyone know what the problem could be? Thanks.
3 Suggested Answers
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 122 Answers
SOURCE: I have a Samsung RF267ABRS
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Posted on Sep 03, 2010
I have a Samsung French door refrigerator model Number RF267AARRS . The water and ice maker are not working. My friend thinks it's because we have the wrong filter but they discontinued the filter for...
says it takes filter part DA29-00003G you can go here and see it
https://www.samsungparts.com/dcwsearch/models/parts/?pc=1&mc=0&model=RF267ABRS%2FXAA&modelcode=RF267ABRS%2FXAA&version=&parttype=WATER+FILTER&spq=
Dec 31, 2017 | Refrigerators
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
I have a Samsung RF267ABRS french door refrigerator. It is two years old and it quit making ice. I have replaced the filter and the water dispenser works fine. I have also reset the ice maker. What can...
Sep 03, 2010 | Samsung Refrigerators
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
