Question about Kenmore Washing Machines
What is water pump part number kenmore washer 90
Need part number for kenmore washer series 90
  • 2,478 Answers
Go to www.appliancezone.com I use them all time.
Posted on Feb 12, 2012
  • 112 Answers
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
If the unit is still agitating as it is supposed to, this is usually due to a faulty lid switch.
Posted on Oct 25, 2008
SOURCE: kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Posted on Dec 11, 2008
  • 113 Answers
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Posted on Dec 17, 2008
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
Posted on May 10, 2009
SOURCE: 90 series Kenmore washer won't spin
You need a new timer. The clicking sound is the timer knob going and your washer not "agitating" is the result of the timer knob not sending the signal to the rest of the machine.
Posted on Jul 07, 2009
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
My 90 series Kenmore washer spins but doesn't
The most likely problem is the drain pump.
Jun 26, 2011 | Kenmore Washing Machines
Where can I buy parts for my kenmore 90 series, specifically the piece on top that tells the washer to run when the top is shut. I have a Kenmore 90 Series 22992 100.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts, part numbers and Sears prices.
If your complete model number is
110.22992100See the following:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22992100&pathTaken=partSearch
I assume that you're talking about the Lid Switch.
Most local appliance parts should have the switch since it is one of the most likely parts to be replaced.
On the Sears site, you may see a comment in effect "manufacturers authorized substitute". If the first three digits of the complete model number are 110, the washer was made by Whirlpool and those are Whirlpool numbers. Again, usually available at appliance parts stores.
Jun 10, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Efficiency of Kenmore 80 and 90 series washers
all front loaders do is save alittle water,motor and pumps aree almost the same,kenmore makes the 300,400,500,600,series know and they will last forever,and if you do need a replacement part they are dirt cheap,because all parts are universal-mike
Feb 05, 2010 | Kenmore 15944 Top Load Washer
Need a water pump for a kenmore 90 series washer.What is the part number?
There are 2 possible pumps.The difference is the hose sizes. One will have a large and a smaller hose 3363394, or 3352293 (Supco LP116), the other both larger hoses 3363892 . Check that first. Those are the Whirlpool numbers, not the Sears numbers.
Dec 31, 2009 | Kenmore Washing Machines
Kenmore 90 series washer does not drain
Check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Vic
May 10, 2009 | Washing Machines
Kenmore Series 90 washer. Will pump the water, does not spin
Replace the motor coupling between the motor and transmission its very easy if you tilt the machine back and remove the two screws holding the motor brackets.
Mar 28, 2009 | Washing Machines
Kenmore washer 90 series Washer will not spin
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
