Question about Garden
Bolens qt 17 no spark - Garden
Bolens 13.5 horsepower no spark
Posted on Jul 16, 2012
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
How much coolant does the 1991 Dodge Dakota take from bone dry?
http://dodgeram.org/tech/gas/specs/5_2v8.htm
17 quarts.
May 02, 2016 | Dodge Cars & Trucks
I would like to know the coolant capacity on a 1996 bmw 318ti
Engine lubricant oil capacity: 4 liter / 4.2 U.S. qt / 3.5 imp. qt with filter change Engine coolant capacity: 6.5 liter / 6.9 U.S. qt / 5.7 imp. qt Fuel tank capacity: 65 liter / 17.2 U.S. gal / 14.3 imp. gal Transmission oil capacity: 1 liter / 1.1 U.S. qt / .9 imp. qt Final drive oil capacity: 1.1 liter / 1.2 U.S. qt / 1 imp. qt Battery capacity (Ah): 50 Spark plugs: Bosch F7LDCR, NGK BKR6EK
Mar 03, 2015 | 1996 BMW 318
Repair and replace power module on bolens culivator 31cc engine
How old is it? Does it show a spark when you remove plug an hold against engine while pulling cord? Did you replace plug? It is the most common problem. Remove the stop wire an try to start, if it does or you see spark the switch is bad. I would check put these things before replacing module.
Mar 16, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
31cc engine specifications
Engine specifications for the flywheel to magnito clearance: Contact Bolens.
Nov 03, 2017 | Bolens 31cc 2-Cycle Gas Cultivator BL410
I cant find the oil filter on my 1985 bolens qt 17
that age might not even have on
Apr 22, 2012 | Garden
I need a wiring diagram for a Bolens riding lawn mower, does anyone know where I can find one?
I am not getting spark to the spark plug, I need a diagram showing the wiring
for the spark
Oct 11, 2010 | Garden
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Garden Logo
203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
