Question about Frigidaire 24 in. FDB2321REC Stainless Steel Built-in Dishwasher
Electorlux dishwasher flashing CL
My electolux dishwasher mode FDB2310LCC2 is flashing CL when I try to start it. The motor will start, but not water is coming out.
  • Jeff_d291 Oct 24, 2008
    Cannot locate any slider switch on the handle. Still flashing CL
  • Anonymous Feb 11, 2009
    I have the exact same problem and its only 3 months old. The motor turns on, and "cl" is flashing but no water coming in. If you know of a sulotion let me know.My name is Steve.
  • Frigidaire Master
  • 19,396 Answers
Error CL means that the child lock had been activated.
To unlock the machine you should put your finger up inside the handle and locate a slider switch, then push the switch to to the left side.
Posted on Oct 24, 2008
  • Ginko
    Ginko Oct 24, 2008
    Try also unplugging from power for ten minutes , to reset the panel.
  • Ginko
    Ginko Oct 24, 2008
    If it still does not reset then it is a daulty door latch, check if the door latch is stuck, if it is faulty, you need to have the part replaced. Here is the replacement part.
Read your owner's manual on how to disable the Child Lock. My Frigidaire (made by Electrolux) has a child lock feature that is deactivated by pressing and holding the "Cancel" button for three seconds.
Posted on Nov 20, 2008
Electrolux dishwasher fdb2310lcc1 flashing cl on display
Hello sandy miller, thanks for your post!
From my understanding your Electrolux dishwasher is flashing "CL". Typically, that stands for close door it could be an issue with the control panel, door latch, or door strike. I would recommend having a professional technician come out to properly diagnosis your dishwasher to avoid any unnecessary part purchases. Hope this helps. -Matt
Nov 16, 2014 | Dishwashers
Frigidaire Gallery Professional Series GPD8998JC0 ... I can press the buttons to choose my settings but my START/CANCEL button won't work. So I try a 1 hour delay which works but then no water nor the...
Hi Joseph - I understand your dishwasher is displaying a "CL" error code. A "CL" code typically refers to the main door switch. The first easy troubleshooting tip is to flip the circuit breaker to the dishwasher for about 20 minutes and see if that resets it and clears the error. If the circuit breaker trick doesn't work, it could potentially mean that the door is not closed completely. However, it could also mean that the control board is not sensing that the door is properly closed. I would recommend checking the door switches. Look to see if you notice if anything is bent or misshapen. Also, you might try the manufacturer site to see if you can download an owner's manual for future reference. They typically have a large number of owner's manuals for consumer use. If you have tried these troubleshooting tips and still come up with a "CL" code, you might need to reach out to a local service tech who can better pinpoint the problem for you. Best of luck!
Dec 19, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
My Electorlux est614 don't drew water. I checked all pipes etc without solution
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 11, 2011 | Dishwashers
How do I cancel the child lock on dishlex dishwasher 2005 model
Hi, ours is the 403 model but im guessing it will be the same operation for ur 302 mod, In prog selection mode press and hold start for 5 secs, indicator lights should flash then CL wiil appear to indicate child lock on........ in this mode by pressing and holding any button for 5secs will temporarily give you access to program setting and control an will auto reactivate after 15 secs, ..... too disengage permanently firstly you must temp unlock as above then press and hold start for 5 secs, CL should display with a long beep to indicate CL is off..
Cheers Jeff QLD
Apr 21, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwasher wont drain
Look for food in sump and drain hose, if clear may need drain pump
Mar 03, 2010 | Dishwashers
Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Mar 24, 2008 | Dishwashers
Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Mar 04, 2008 | Dishwashers
Dishwashers Logo
687 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
