Question about GE WPRB9250C Top Load Washer
Fill but not spin G E wprb9250c
I change lid lock and still making click noise in the control panel.Already change the control panel. I run the test with error code and show no error code. Do i have to reset something?
  • GE Master
  • 19,396 Answers
It pumps, but doesn't spinIf your washer pumps the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • From Repairclinic.
    Posted on Oct 24, 2008
    What is wrong with a washer that fills up with water lid lock clicks but will not do anything else just clicks?
    LID LOCK LIGHT STAYS ON NO START:
    Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
    MACHINES SAIDS SENSING
    When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
    will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
    added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
    NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
    Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
    Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
    This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
    I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
    Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
    A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
    The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
    The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
    God is good and that's why I give free advice.
    May 14, 2015 | Whirlpool WTW4800XQ Washer
    WASHER WONT START
    HI,
    f your washer doesn't seem to work at all, check these:
    No power
    Lid switch
    No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
    Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
    Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
    Aug 26, 2008 | Maytag PAV2300 Top Load Washer
    Washer only stays on rinse cycle
    The first thing to check in a no-spin condition on any washer is the lid switch. The whole purpose of the lid switch is to stop the tub from spinning when the lid is opened and this should also cause it not to drain or fill. It’s a safety thing.
    A quick check of the lid switch is to slowly raise and lower the lid a little bit and listen for a faint clicking sound. This is usually a pretty good indication that the lid switch is working but it’s not definitive. A better test is to put an ohm meter on it and test the switch. You can access the switch by removing the washer cabinet.
    The lid switch will most likely look like one of the two pictures below. You can click the pictures for a larger view and to order the part.
    Older-style Lid Switch
    00094434.jpg Newer-style Lid Switch
    May 06, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
    WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
    Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
    Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
    Dishwasher will not run.
    Remove the lower arms and anything else attached to the motor from inside the unit, then try it again if the shaft spins motor is OK, but one of the arms etc, is jamming it.
    Aug 08, 2014 | KitchenAid Dishwashers
    The lid lock light won't stop blinking.
    LID LOCK FAULT
    Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
    Lid is not closed completely due to interference.
    Check for lock interference with lock striker.
    Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
    Main control detects open lid switch when attempting to lock.
    Main control cannot determine if lid lock is in a locked state.
    Perform the following checks if the washer does not lock (or unlock).
    1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
    2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
    Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
    Washer just makes clicking sound .Filled with water but won't run now just makes clicking sound.Tried all cycles it makes a little different click when I put it on drain/spin then selected no spin.but...
    f the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
    Jan 03, 2011 | Washing Machines
    Wont spin or start
    Check your lid switch. It is either located under the lid on the right side, Or under the control panel. Make sure it clicking. If not your lid switch is bad replace.. and your good to go.
    Nov 18, 2008 | Kenmore 24032\24036 Top Load Washer
    Door Lock Clicks/Makes noises Washer does not agitate/spin
    Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
    Apr 18, 2007 | GE WSXH208A Front Load Washer
    GE WPRB9250C Top Load Washer Logo
    59 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
