Harddrive not responding extranal data - Computers & Internet
    Genius:
  • 1,011 Answers
Dear,
what do u mean by external data
regards,,
Posted on Oct 24, 2008
How do I clear miscellaneous data memory.
If you reset to factory default that wll clear all extraneous data but you will have to set up from scratch. The used data might be the operating system and standard apps/utilities/games etc
Jul 17, 2015 | Samsung GALAXY S4
Got a message sent to me picture I go to call it up and it says not enough disc space
Free up disk space, get rid of the extraneous stuff/data on your device. add an SD card if you can
Jun 06, 2015 | Samsung Cell Phones
Connections to the hard drive
The Harddrive is a SATA unit.
Uses a SATA data cable, and a SATA power cable.
SATA data cable, and connector on motherboard, example;
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Between the SATA data cable connector, and the SATA power cable connector; the SATA data cable connector is the shorter of the two in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
The connector end used on the harddrive side, and optical drive side, (CD/DVD drive), is usually a 90 degree Bent Elbow.
The connector end that plugs into the motherboard, is a Straight connector.
NOTE* Color of connectors does NOT matter.
Most of the time the SATA data connectors on the motherboard, are different colors.
This is to help discern what number of SATA data connector it is.
Four SATA data connectors on the motherboard?
SATA 1, SATA 2, SATA 3, and SATA 4;
Or:
SATA 0, SATA 1, SATA 2, and SATA 3?
SATA 0, or SATA 1, is usually reserved for the Harddrive.
The Primary harddrive with the Operating System on it.
(Unless you have harddrives set in a RAID configuration)
DOES NOT MATTER WHAT SATA DATA CONNECTOR, you plug into, on the motherboard.
Want to plug the harddrive into SATA 3, or SATA 4?
Go ahead.
NO matter what SATA connector on the motherboard that you plug into, BIOS will find the harddrive.
Note the L-shape in the connector.
Has to line up on the L-shape on the harddrive, optical drive, or motherboard, SATA data connector.
There is usually a lock on the connector. This you may not see.
Sometimes there is a little 'bump' on the connector. Depress with the thumbnail to install the cable, or remove.
This is an example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF, your SATA harddrive has a provision for plugging in a SATA power cable, AND a 4-pin Peripheral power cable; ONLY plug the SATA power cable in.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Using BOTH types of power cables will BURN the harddrive up.
May not happen right away, but I assure you it will happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/SATA
Dec 10, 2012 | Acer Aspire X1 AX1470-UR11P Desktop PC...
Hello, i have a VERBATIM hard drive USB 2.0 it cost me a lot of money :-( i've hardly used it! it has been handled in cotton wool tonight, when transferring data to it from my computer it has...
1. First power down the computer and the external hard drive.
2. Disconnect the drive.
3. Wait a minute.
4. Start your computer.
5. Connect the Verbatim drive again.
6. Wait a minute. (While waiting, check the screen for popup messages telling you the harddrive is ready and received a drive letter.)
7. Check "My Computer" for the harddrive.
8a. If you see it there, click it and make a copy of the data you have stored on the drive immediately!
8b. If the drive does not show up, you probably have a problem that will take deeper looking-into.
A clicking sound from a harddrive is never a good sign. While it does not mean immanent ***** of the drive, getting the data from it is now a matter of luck. In any case you should not trust the drive and should replace it as soon as possible.
Jul 01, 2017 | Verbatim SmartDisk Firelite Portable USB...
My seagate barracuda 7200.9 120GB hard disk hardware board emitted a smoke when i switched on my PC.I found out a small piece of part of the board (black color) showed signs of burnt.I could hardly read...
regan_santos it is against FixYa Terms Of Service to post an email address, or respond to one.
Just pointing that out.
From my own small piece of advice, I would replace the circuit board with one from another Seagate 7200.9 Barracuda Plus 120GB harddrive. Buy a good used one.
This way you can install the circuit board on the one you want to retrieve data from, then reinstall it back on the one you bought, after you have retrieved your data, and have a working Harddrive.
Buying just that circuit board? Mmmm, no.
Just from a quick search,
http://www.serversupply.com/products/part_search/pid_lookup.asp?pid=52592
http://www.allhdd.com/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&cid=0&q=ST3120026A&src=ggl
Information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm
Do I know if the damage has gone further than just the circuit board? No, I do not.
Therefore it is a decision only you can make if it is worth the money spent.
There are also professional data recovery services. ($$$$$)
Nov 16, 2010 | Seagate Barracuda 7200.7 Plus (ST3120026A)...
I have ROCO 320 GB extranal hard disk which is not recognized in my laptop windows 2007. I had stored so many data from my desk top computer. Any solution please.
Connect your harddrive to another computer like windows xp then if it is recognize then take data backup . If your harddrive is fine then follow below for laptop. First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Sep 14, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Driver failure
if your using Extranal HDD then frist change your Harddrive case may be problem with case only
Apr 22, 2010 | Computers & Internet
External harddrive (MyBook) not recognize
Okay, here is what you can do to just verify that you haven't lost all the data on the hard drive (HDD failure, due to the manufacturer or a drop or heavy shake). Download a copy of Slax Linux www.slax.org 32 bit version will work, and burn the ISO they give you to a CD. I would recommend using Alcohol 120 www.alchoholsoft.com. Boot in Slax, and see if you can get the computer to recognize the HDD. If so, backup your important data onto other hard drives or thumb drives. Then when you have enough data backed up, you can format the hard drive.
Now, to get really fancy, lets say you have a somewhat corrupt formatted hard drive, and enough data free to encompass the data you have on the hard drive. Well, what you can do is download a program called "partition magic" and do a partial non-destructive re-partition. Respond if you need to get to that point so I can get you a link to the program.
Nov 11, 2008 | Western Digital 320GB MyBook External USB...
External USB drive making clicking noise - Windows does not recognize it!
The drive is damadged bad. youll have to go to a data recovery centre, but that can cost $700+ if you really want your data back.
Sep 19, 2008 | Western Digital (WD1000VE) 100 GB Hard...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
