Question about Hotpoint Dryers
MAKES VERY LOUD NOISE FULLY LOADED - Hotpoint Dryers
    President:
  • 2,468 Answers
Sounds like the plastic door bearing and green and white drum slides are getting bad,remove control panel,then the 2 screws in the door frame top located at the top of the door opening when doors open,remove top,then inside on both sides there are 2 phillips or hex head screws,remove these and this will let the front door and panel pull out toward you,then the door bearing and glides will be in this front panel
Posted on Feb 13, 2012
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
My Kenmore Washer Elite HE3, front loaded, makes a very loud knocking noise when it spins ?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Nov 09, 2010 | Washing Machines
Proline tumble dryer TDC6A makes a loud grinding noise.
Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
Dec 09, 2009 | Dryers
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
Dell optiplex gx280 makes loud fan sound at startup and enters windows screen, but will not finish booting and freezes up.
You may have a problem with your power supply(the loud fan noise) and eventually it may get too hot and will cause problems like not fully booting.
Jun 12, 2009 | Dell OptiPlex GX280 PC Desktop
Makes a loud noise when it is turned on. Can't open it.
If it is making a loud humming sound it is probably getting weak and will have to be replaced. Is it doing it in all speeds? Motor replacement would probably not be worthwhile unless it is a very expensive unit. I'd opt to replace the unit.
May 16, 2009 | Bionaire BT45RC Tower Fan
Vibrating noise
u may have food in pump u see sometimes it dose happen i have pop corn seeds in mine
Dec 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Drum turns but not when it is fully loaded
Do you hear a loud hum when fully loaded? Or does it go away when empty?
Sep 20, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
187 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
