Question about Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave
Where is fuse on microwave model mh7130xeb - Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: microwave MH7130XEB-2 stopped working while
There are 2 fuses in your unit.
The line fuse: (Item 14) (20 A)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260484&diagram_id=93994#d93994
and the Thermal Fuse (Item 5) same link
Either of the 2 can cause your unit to no longer operate. Most of the time the failure is the line fuse.
Thanks for using FixYa.
Kelly
Posted on Mar 19, 2010
My Intellichef microwave model #K0936 has stopped working. I've tried different outlets but the microwave is not responding. Is there an internal fuse that has blown or is the microwave dead?
If the fuse is blown the microwave will be "dead". The fuse is accessed by removing the cover. You can usually find the fuse by following the power cord into the microwave. Unplug the microwave and don't touch anything except the fuse as the capacitor can hold an electrical charge.
Nov 02, 2017 | Microwave Ovens
MICROWAVE OVEN "DAEWOO" MODEL KQG-868G PROBLEM :
There should be 3 'fuses' inside a microwave. The 'line' or monitor fuse, the magnetron fuse or TCO (thermal cut out) and the cavity temp fuse. I'm trusting that you have verified that the outlet is 'hot' first. Be careful !!
Nov 03, 2013 | Microwave Ovens
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
Where is the fuse located in a GE Spacemaker II microwave model number J EM824_ _ _ ? I can't read the rest of the model number.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a whirlpool MH7130XEB 1; cooktop/counter light will not work. Have changed bulbs so it is not the bulbs. Is there a trip switch located in the microwave that I can reset or is there another possible...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 01, 2011 | Whirlpool Microwave Ovens
It just quit while cooking. Is there afuse in this microwave?
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 12.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 27, 2010 | Maytag MMV1153A Microwave Oven
Microwave MH7130XEB-2 stopped working while cooking. Is now dead. Check plug and breaker box, they are ok. Is it an internal fuse? If so what part # do I need?
Hello :
Problem with the power transformer or the power PCB . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service .
You could check for manual here :
Whirlpool MH7130XE Microwave Oven manual .
good luck .
rate please !
Mar 19, 2010 | Whirlpool MH7130XE Microwave Oven
Whirlpool MH7130XEB-1 blows 20a line fuse when I use the oven. no problems with any other functions of the microwave
hi,you need to check wires to the bake element or broil are not touching the metal case...check your power cord going into the back were the wires hook up...you have a direct short....check your switches carefully....i hope this helps....
Nov 05, 2009 | Microwave Ovens
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave Logo
66 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
