Question about Dryers
Hoover nextra hnc 375 t dryer
My drier runs for maybe 2-3 mins then cuts out ,the heater is working -is one of the thermostats for control and the other for safety if so could you tell me which is which and do you think it is possibly the control stat not working and the drier cutting out on the overtemp(safety )stat. Please could you advise.
4 Suggested Answers
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
vickygomar
  • 460 Answers
SOURCE: Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
Posted on May 15, 2009
canwoodjc
  • 3301 Answers
SOURCE: i have a hoover nextra
the filter care light comes on when the machine is over heating so the "brain" thinks the lint trap is full , clean the entire venting system, including the outside vent cover and remove any debris , then unplug the machine for a few minutes and see if it resets
Posted on Jul 04, 2011
I have a hoover nextra dryer hnc 170. The drum will not turn, and both the lights for filter care are on. I assume the reason it is not turning is because of the filter care light. Is there anythin i...
Jul 04, 2011 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
thank you
May 14, 2009 | Dryers
Dryer not working
thermostat on top of dryer heater may need to be reset . Unplug and remove top and just push gently the thermostat (red) you may hear it click .now reset or perhaps a lead as broken to the dryer heater .
Jun 28, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover nextra mega load 7.5kg HNC175 condenser dryer has 1)stopped heating, the drum still goes round and cold air goes in. 2) The filter care light is on, i have taken out the condenser assembly and...
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Apr 03, 2008 | Dryers
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Dryer stuck in sensing mode
Since no help was available without premium assistance, I actually contacted a repairman. He performed all the tests again and told me the problem was the control board. Then wanted $600 to fix. I found the part online for $150 and fixed it myself in about an hour. Instructions were easy.
Sep 08, 2007 | Hoover HDC6 Electric Dryer
Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Nov 04, 2006 | Hoover Nextra HNWF 3135 Front Load...
Dryers Logo
Top Dryers Experts
