Question about Teac PLD2000 System
No signal to the television set
The dvd player functions and reads the remote controll normaly and is correctly connected but the television set states there is no signal.
  • Anonymous Feb 14, 2009
    Samsung-vr355, dvd running but "no signal" on tv-set.
    Problem Solver:
  • 10 Answers
Make sure that the DVD player's output is properly connected to the proper input on the TV, (Video1, etc.).
Posted on Oct 24, 2008
My problem is getting a "This signal is not supported message" on an HDMI input into a Pioneer PDPR05G media receiver.
No need to understand - just read the message, It clearly states that the unit will not accept that particular signal because its electronics are not configured to deal with it. And that is it - end of story.
Basically, you cannot force a square peg into a round hole.
Mar 13, 2017 | Pioneer Televison & Video
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    My television picture does not appear on my zone 1 and zone 2 television. I just get a blue screen although I get audio. The crazy thing is that when the function is set to DVD. I get the picture. I...
    Hi. Most likely the assigned input isn't correctly setup. Try this:
    1. Press 'setup' on your remote control.
    2. Navigate to 'Input Assign'.
    3. Navigate to the correct next option (HDMI/Component/Digital) - this depends on how you have connected your DVD player up.
    4. Find the name of the connection you've plugged your DVD into (physically look at the back of the receiver).
    5. Select the DVD option, and press left/right until you have selected the correct input.
    You may need to change to Tuner then back to DVD, but that should do it.
    If you need further help, please let me know exactly how you've connected your DVD player (HDMI? component?), and the name of the physical connection you've plugged into.
    Hope that helps!
    Mar 04, 2011 | Onkyo TX-SR876 Receiver
    I lost my remote and bought a innovange jumbo remote but cant figure out to program the remote to the dvd player. can you help?
    First, make sure the device you want to connect with your remote is turned on, whether that's the television `, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV,DVD etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
    Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
    If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
    Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
    You can find the codes from below website
    http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
    Thank you
    Oct 18, 2010 | Durabrand DVD-1002 DVD Player
    I have a Toshiba SD-K860SU DVD video player that I have connected to my Panasonic TC-32LX60 LCD TV, but I cannot get the DVD player to work. My TV is connected to my Comcast cable service black box. Should...
    You should use the component video input (which ever the TV has), you will get better pictures than the S-video.
    As far as the remote control for the DVD, keep using the one that comes with your DVD player, Comcast remote does not always work, beside you get full function using the DVD's remote, that is how I use my DVD, same for the TV, Comcast remote my not be able to send out the signals to the ATV for selecting the input sources on the TV. Comcast remote is not a full functions remote.
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://s807.photobucket.com/home/budm/allalbums
    Aug 06, 2010 | Televison & Video
    Remote control stopped working. no signal
    I apologize if I am stating the obvious. Replace the batteries with NEW ones and be sure they are installed with the correct polarity. Also, assuming this is a multi function remote, press the TV function button on the remote. Often a remote gets inadvertently set for dvd, or tuner control and then will not control the TV. My Samsung remote for example can control a stereo, vcr, cable box, and dvd plater in addition to the TV. If none of these simple fixes solve the problem you will most likely need to replace the remote. Try partstore.com
    Nov 16, 2009 | Vivitek V37835 46 in. LCD Television
    Tv screen is white; sound is ok
    Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
    Apr 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
    Dvd wont work.
    First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
    Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
    Older ge tv but cable ready-no remote.... need to find channel to play dvd player on.Recently connected dvd player but can't play a dvd.The tv is connected to a cable box.
    Hey wegodsky,
    If you're not able to find the right channel on your TV to use your DVD player, you may want to try changing the TV's input source instead. Many TV models will require that the TV be set to an external antenna in order for any other device (like a VCR or DVD player) to function correctly. This can usually be done by pressing the menu button on the TV itself and selecting an option similar to "Input," "Source" or "Antenna" if you do not have a remote control for your TV.
    Hope this helps you out.
    Sincerely,
    Aaron
    Go Ahead. Use Us.
    Jun 19, 2008 | Televison & Video
    Teac PLD2000 System Logo
    139 people viewed this question
    Top Teac Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
