Question about HP Photosmart R707 Digital Camera
Flash problem HP R707
HP R707 My camera when requiring the flash to opperate just says on the screen CHARGING FLASH and will not go any further , Flash will not work and no other functions will work ! you have to take the battery out to get it to work, it will work perfectly ok for day shots.......
  • 6 more comments
  • Anonymous Dec 27, 2007
    Got the same problem. Tried the pin trick, new battery... nothing helps.
  • Anonymous Apr 27, 2008
    Got the same problem. Tried the pin trick, new battery... nothing helps. I think HP should sort out the problem, its obviously a design fault, Im going back to my trusty OM1!!
  • pastu May 14, 2008
    what I did was that: when the camera was connected in to the computer, I opened the camera's folder I did format, and now the camera doesn't work at all so could you tell me or let me know if is possible to fix it up, or I have to buy a new one!!
    sorry is not really a flash problem
    thanks
    ivan * ivandafe@hotmail.com
  • rpddetective Aug 09, 2008
    I have the same problem, I tried all of the other methods described earlier, which did not help. I found only one way to prevent the "charging flash" lock up of my camera, which is to torn off the flash.
  • Anonymous Feb 01, 2009
    I'm havIng the same problem and just followed all of the suggestions. New battery fully charged and took out memory card, used the paper clip and put card and battery back into camera and it took 2 flash pictures, turned it off and now it will not turn back on. I have already had this camera replaced and have a feeling this is just a problem product. I have always been happy with HP products, but not this one.
  • Doreen Smith Mar 14, 2009
    I have a HP707. My problem is I can only scroll the pics one way{to the left when I want to view them}i in the camara> Any ideas???
    I have a HP 707. When I want to view my pics in the camara they only scroll to the left. Right side does not move. Any help would be appreciated!!!!!!!
  • Anonymous Apr 11, 2009
    I have the exact same charging flash problem.  I tried the paper clip suggestion and it didn't work. I'm starting to think it's time for a new camera.
I tried the paperclip solution above. I held the paperclip in for 10 seconds, inserted the battery & memory card back in, but the problem persisted. So I tried it again, but this time held the paperclip in for 40 seconds, reinserted the battery & memory card, waited about 10 seconds, then turned the camera on. This solved the problem!! Try holding in the paperclip for at least 40 seconds, rather than 10 seconds.
Posted on Dec 20, 2009
I've just spent 30 minutes on the phone (premium rate) to HP re this problem. The solution was as follows: switch the camera off take the battery and any memory cards out press the end of a paperclip into a small hole (which you can see with the battery compartment open) remove the paperclip after 10 seconds put the battery and memory card back in and the problem should be sorted. HP also suggest upgrading the camera firmware (which you can do via their website)
Posted on Aug 23, 2007
Followed the paper clip instructions and walla it worked and the camera is working properly Thanks
Posted on Jun 12, 2008
  • 4 Answers
I commend eevie010166 for his/her solution. I followed the advice of all the previous posts and failed to revive the camera. After holding the paperclip down for 40 and more seconds, the camera is back to normal. Thank you!
Sincerely,
John Coffey
Posted on Dec 30, 2009
I have the same problem with my R707. After going through battery, charger pin pushing and all that wonderful stuff, the CS at HP suggested that it could be the the FLASH bulb and that there is no way to change this bulb hence it can not be fixed.
Posted on Dec 16, 2007
We have the same problem and were also told by HP that the problem is the battery. A new and fully charged battery failed to solve the problem. I tried the paperclip method in a previous post - that didn't work either. We noticed that this problem started after downloading the updated firmware issued in connection to the June 2006 recall involving firmware that controls the battery charging functions. Our camera was fine prior to that install.
Posted on Sep 28, 2007
    Problem Solver:
  • 22 Answers
I also have the HP R707 and have similar Flash problems. My camera will flash, but about half the time after using the flash, the camera locks-up... the only cure, like yours, is to remove the battery. And like yours, non-flash pictures are just fine. Having a strong charge on the battery probably helps, but I think it is probably a design problem.
Posted on May 30, 2007
    Problem Solver:
  • 8 Answers
See if the flash works fine when the camera is plugged into the charger? If so, it is likely that your battery is not holding a strong enough charge. Charge the battery overnight and see how it works. If that doesn't help, buy a new battery.
Posted on Feb 18, 2007
My HP r707 is doing all of the above. I took the battery out but I must be crazy because don't see any hole..description please!! TY
Posted on Jul 04, 2008
I have a HP Photo Smart R707 with a fully charged new battery and the flash won't work. Keep getting charging flash. Any help on this?
The flash mode has to be set.
There are 5 flash modes:
  • auto - flash fires when needed
  • red-eye reduction - flash fires when needed, but there's a pre-flash to minimize red-eye
  • flash on - flash always fires
  • flash off - flash never fires
  • night - flash fires if necessary (and uses red-eye reduction) to illuminate foreground objects, but shutter stays open to record the background by ambient illumination
http://www.bobatkins.com/photography/digital/hp707.html
Aug 11, 2010 | HP Photosmart R707 Digital Camera
What does charging flash on photosmart m537 mean?
The flash gun needs to have a high charge available before it can flash - this can take a few seconds to charge fully ready to give off a full flash "flash" As batteries get older and uncharged - it takes longer to reach the correct charge on the flash
Hope that helps
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Photosmart R707 Digital Camera
Continous "charging flash" when trying to snap a picture
Connect the camera to the charger and take the picture. If the charging flash stops after a couple of seconds, it means that you need a new battery.
Jan 08, 2010 | HP Photosmart R707 Digital Camera
Having trouble with the flash on my R707
You need to be more specific. Try to run self-diagnostics tests - press flash button while switching the camera on. One of those tests checks the flash.
Dec 14, 2009 | HP Photosmart R707 Digital Camera
The camera turns on and takes pictures but the flash doesn't work. I saw the number 403 on the screen when I was trying to figure out the problem.
Try to run self-diagnostics tests - press flash button while switching on the camera. One of the tests verifies the flash functionality.
Oct 25, 2009 | HP Photosmart R707 Digital Camera
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
Hp 717 has to wait to take the piture it says flesh charging
I highly recommend you go to hp.com and get help with the free chat service available to hp customers. I have been able to fix all my Hp stuff there - they know everything there is to know about Hp devices.
Dec 10, 2008 | HP Photosmart R707 Digital Camera
My Photosmart 967 wont flash, Msg says "charging flash" but it doesn't flash
You will need a new camera circuit board. The charge circuits have failed. There is no easy fix for this problem, sorry.
Nov 14, 2008 | HP Photosmart R707 Digital Camera
R707 Fails diagnostic test 10 (strobe)
I found my answer to this on another board. Remove the battery and SD card. Use a paperclip to press in the small siver dot above the + sign for about 10 seconds. This resets the firmware.  It worked for me, hopefully it will work for you too.
Jul 13, 2008 | HP Photosmart R707 Digital Camera
Help
charging flash means then the camera is charging the flash light,, thats not a problem,, just wait for a couple of min, , and then take photos,, hope i helped ya
Jul 05, 2008 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
812 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
teddyboy
Are you a HP Camera Expert? Answer questions, earn points and help others
