Question about Citizen Watches
Mode dial on eco drive navihawk black eagle won't
  • 20 Answers
SOURCE: analog will not sync with digital
I just bought a 4756. Hard to follow that manual.
In the end I used these parts of the manual
Step 1 was to set the correct time zone (off PT or pacific time to ET eastern Time.)
Step 2 was to do a manual receive of the radio time.
Step 3 was to Home all the analog hands so they all pointed to 12. see manual
Step 4 then I hit B button - top right by the 2 and everything spun around to the right time received from the manual received time.
Posted on Feb 11, 2008
Techjoel
  • 79 Answers
SOURCE: changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
Posted on May 14, 2009
  • 67 Answers
SOURCE: hands don't move - digital stuff works
the hands could be silghtly bent or to tight for them to move if not change the battery
Posted on Jun 02, 2009
  • 183 Answers
SOURCE: My Citizen Navihawk analog hands work, LCD Blank??
Being able to tap it and bring it back is a sure sign that there is a contact problem most likely in the circuit board. This is the worst case scenario. I would try going to a watch maker/technician to see of having the watch AC'd or reset fixes the problem. If not then I would have them look at the circuit board/movement. This may have been damaged during battery placement from too much pressure.
If you have trouble finding a qualified watch maker/technician you can go to Citizen.com to look up their service center or an authorized service center near you.
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: I have a C300 Citizen
yep. reset it to zeros and then set the time and they will match. here is where to get the manual (get the C300).
http://www.citizenwatches.com.au/instruction-manuals
Posted on Dec 04, 2010
How do brighten the dial so I can see the time in the dark. The watch was in direct sunlight 3 days & I still cannot see thedial in the dark!
At one time luminescent dials were made with Radium Luminous paint with a half-life of 1600 years so the "glow" didn't go away soon. And getting enough of the material to cause it to glow sufficiently was dangerous to the wearer. Since then Tritium mixed with zinc sulfide was substituted. Please see: http://wornandwound.com/2013/08/23/seeing-in-the-dark-luminescence-in-watches/
Later, non-radioactive materials were used. Unfortunately, all these materials decay and are less efficient. If you have a small flashlight you can hold it to the face of the watch and it will then get brighter...for a while. But, soon it will fade again. Holding the watch under a light for a long time won't help. The reason is that the material can't hold a "charge" and the excited materials have lost much of their ability to luminesce.
Dec 27, 2014 | Citizen Watches Citizen Eco-Drive Black...
Why won't my "solar" powered watch charge/work any more?
Some of these eco-drive watches use a swinging weight self winding mechanism (albeit through a generator) or a solar cell under the dial, some use both. Either way the capacitor is the thing that holds the charge and once that fails it will need replacing. Sometimes not as straight forward as replacing a battery as you nay have to remove the auto weight and sometimes usually on the solar ones its just a case of popping it out and a new one in. They are quite difficult to identify and get hold of but they do differ from normal batteries as they come with 1 of the contacts attached to them to prevent fitting an ordinary battery by mistake
Feb 02, 2013 | Citizen Watches
I put a new battery in a citizen navihawk thunderbird watch. How do i progam it now?
an Eco-drive does not have a battery, it has a rechargeable power cell that is charged by light through the face of the watch. If you have replaced this cell you may have damaged the watch. If the cell was not soldered in, replace it and put it under a fluorescent light for a little while (several hours) and it should start working.
http://www.citizenwatch.com/COA/English/faqs.asp?topic=Eco-Drive
http://www.citizenwatch.com/COA/English/rechargeguide.asp
http://en.wikipedia.org/wiki/Eco-Drive
Jun 14, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Dont know how to set time on a eco drive 820
Are you referring to Eco Drive E820? If you do here are the simple steps that can help you.
-Pull the crown out one notch
-Rotate the crown to align the mode hand with time/calendar[TME] as indicated on the mode sub dial.
-Pull the crown out two notch
-press the upper right button above the crown.
-Rotate the crown to adjust the time.
For step by step procedure with visual, click on the link.
I hope this will help you resolve the issue.
Thank you for choosing Fixya.
Mar 05, 2011 | Citizen Watches
Set time
Pull the middle dial out all the way and turn clockwise to move time forward and counterclockwise to move time back.
Mar 02, 2011 | Citizen Eco-Drive Aqualand BJ2060-58E...
How do I find out on my watch how far from leap year we are .its acitizen eco-drive
Pull out the crown to position 1 and the second hand moves to the month position while the small dial moves to the years since last leap year position.
If you haven't got a manual to fully understand what the indications mean, go to "citizen.com", click on "Technical Support"amd then on "setting instructions".
Enter the number required off your watch and click on "get setting instructions".
Jan 31, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Hello. I let a Citizen Black Eagle Skyhawk run completely. Even after charging it for 24 hours, the watch will not run. What is my course of action? Send it in?
After charging the Skyhawk/Black Eagle watch, you need to reset it.
Here's how to do it:
Turn the crown (knob) until it's in chronograph mode (CHR), then pull it out to TWO clicks. Push both buttons at the same time and the display should turn on. The push the crown back in to complete the reset.
If that does not work and you are 100% positive it should've charged...take it in for service. It could be a bad battery (rare).
Aug 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
Mar 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Set New city time-Citizen Blak eagle -c652
Follow this link and see the setting for yourself:
http://www.citizenwatch.com/COA/English/settings_int.asp?caliber=C650&interactive=C650
Rate me, please.
Mar 14, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
65 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
