Question about Vacuums
How do i replace the impeller on shop vac qps20?
Can the old impeller be reused after removing from the shaft, or do I need to reinstall a new one?
3 Suggested Answers
SOURCE: I have a shop vac.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794495
Generic problem for all Vacuums
I have a shop vac.
Posted by mymino on Jul 17, 2008
I have a shop vac. model 500x 1h.p. Center section separation impeller cost of new? Or throw away?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are only 2 ways that I can think of in answer to your question. Either you can replace the fan impeller or you have to replace the entire motor. You would have to contact your local vacuum cleaner dealer in your area or contact the Shop Vac factory @ the website or to call the factory @ the phone 3 listed below; or check your owner’s manual.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
Shop-Vac Corporation
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 17, 2008
  • 15 Answers
SOURCE: removing impeller from sears shop vac
The impellar will screw off with a clockwise rotation and the new one installed with a counter-clockwise movement.
Posted on Aug 21, 2009
Does shopvac series 90ln have brushes in motor & how to replace them
A lot of shop vac motors have brushes, due to the motor's power needs. Unplug it (obv) and get to taking off all the covers until it's just you and the motor. On most shop vacs, you shouldn't need to remove the impeller (fan), and it's better just left alone. The brushes are usually just under spring tension.
Jan 28, 2017 | Vacuums
I need a caster foot for the shop vac qps20
Best thing you can do is pull the other three off and throw em away or else glue them on the wheels being detachable means they get lost every time
Sep 24, 2015 | Shop Vac Vacuums
How to repair drive pedal kirby
You will need to remove upper cover ,then remove the three screws
holding the trans in. Slide out the old drive pedal reuse the cam arm
and install new pedal. Slide trans back in and reinstall belt,reinstall rear screw first then the other two . replace cover and test N/D pedal.
Jul 30, 2014 | Kirby Vacuums
Shop-Vac 6.0 hp Peak 12 Gallon 'Exploding' after 10 seconds of use. Happened twice on two different brand new Shop-Vacs.
Since you said you were sucking water out of a "trench" I would bet there was some debris in the trench that impacted the impeller on the vacuum and caused the metal impeller to fragment, taking the plastic pieces with it. It is highly unusual for this to occur on vacuums if some type of debris, such as a small stone or piece of metal does not reach the high speed impeller/fan. I suggest using either a foam sleeve over the filter cage, or an old nylon stocking if you can get one, to screen out the debris that will cause this condition.
Nov 20, 2013 | Shop Vac Vacuums
Removing impeller from sears shop vac
Aug 21, 2009 | Vacuums
I got a new filter for my Beam central vacuum. How do I replace it? Do I take off the top lid of the canister?
You would not normally need to replace the filter unless it is damaged. Access is from inside the tank itself. Remove the bucket and locate the finger loop on the existing filter. Pull toward the inside of the bucket. Replace the filer by setting in it's track and snapping tight to the wall of the vac. Unless damaged you can save and clean the old filter for reuse.
Jun 10, 2009 | Beam Industries 2900 Serenity Plus Central...
Need to replace power cord on Hoover windtunnel need wiring help
without seeing this it would be difficult to describe. I would take it to a vac shop and let him show you. there are no real schematics for the wiring of these units. I usually would cut off the cable with a few inches of insulation to know where to install the new one and reuse the old terminals if needed.
Feb 24, 2009 | Hoover U5399-900 WindTunnel Lite Upright...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a shop vac. model 500x 1h.p. Center section speratedon impeller cost of new ? or throw away ?
I have a shop vac.
2323 Reach Road
P.O. Box 3307
Go Ahead. Use Us.
Jul 17, 2008 | Kenmore Progressive Bagless Upright with...
Has no suction
I just went through the same thing.  Your fan or impeller is probably broken off the shaft and no longer on the motor shaft.  My local repair shop wants $9 for the impeller and $29 to replace it. You will have to take the thing apart and put on a new fan or impeller blade and I'm still trying to do that to my vac.  I think I will have to heat the nylon impeller with a hair dryer to get it onto the shaft and then tighten the left hand nut. My vac is held together with torx screws so add a torx screwdriver to the price if you don't have one and want to do the job yourself.
Aug 19, 2007 | Eureka Whirlwind 4383 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
