Question about Husqvarna Chain Saw Maintenance Kit 357xp 359
Husqvarna 359 spark plug gap - Husqvarna Chain Saw Maintenance Kit 357xp 359
2 Suggested Answers
  • 3600 Answers
SOURCE: Husqvarna 359 EPA - no spark. I replaced the spark
check the kill switch button wire see if it broke off that happened to mine an dcaused a no start and if the air filter is not clen it won't run eaither.
Posted on Jun 27, 2009
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
Spark plug gap on husky 350 chainsaw
The plug should gap at 0.5 mm or .020" and be sure to use the proper resister plug. Do not cross reference a plug.
May 25, 2014 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna 359 - No Spark
remove the side cover and then the small wire to the coil check for spark again if still no spark the coil is bad if you get spark back the problem is the switch or wiring
Oct 04, 2012 | Husqvarna Garden
Magnito clearence
Hi Stanley, 8 thou is the correct gap. regards Phil.
Aug 25, 2012 | Electrolux 10pk / Husqvarna 55 372 395 455...
Plug settings for husqvarna 460 rancher
If you're referring to gap settings, whatever the gap is when you get the new plug from the manufacturer will be sufficient. You can purchase replacement spark plugs from PartsBuggy.com.
Nov 26, 2011 | Husqvarna Garden
My 359 saw will not start was running then i cut it off would not restart looks like fuel is comeing out of mufffler it is getting a spark
Try a new plug.the gap is .028-.030.Sometimes the plug gets wet and won,t spark hot enough too rerstart.
Nov 23, 2010 | Husqvarna Garden
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the...
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Nov 08, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
May 15, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna 359 EPA - no spark. I replaced the spark plug. is there a reset button? What do I check?
Jun 27, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw Maintenance Kit 357xp  359 Logo
220 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
