Question about Sony KDF-37H1000 37" HDTV
Sony KDF-37h1000 power light flashes 7 times
Power light flashes 7 times
  • 1 more comment
  • Greg Stephens
    Greg Stephens Nov 02, 2013
    7 flashes means a HIGH TEMPERATURE OR SENSOR CONNECTION...!!
  • Greg Stephens
    This is according to the service manual to the KDF-37H1000...!! But the manual does not say how to fix..!!
  • Greg Stephens
    Maybe I need to check all connections...??? Does antone have any suggestions...???
SOURCE: Sony Wega kdf-55wf655 rear projection set keeps turning on and off
Changing the bulb is the best solution, Changing the power consumption settings is only a temporary fix and you should always have a replacement bulb on hand.
Bulb life really depends on how many hours of use it has. If you watch tv more or turn it on and off frequently, bulb life will decrease. That is why people have problems as early as 2 years and some 4 to 5.
Currently I still have my original bulb that came with the TV. I had problems with it in January and its now June. But I do have a new bulb ready.
Posted on Jun 01, 2008
  • 41 Answers
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
This sounds so simple, but this is what i gathered from Sony's website. Sounds to me like it may be a service issue.
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Posted on Dec 05, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Posted on Jan 27, 2009
welcomejee
  • 10594 Answers
SOURCE: Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Posted on Oct 21, 2009
welcomejee
  • 10594 Answers
SOURCE: replaced bulb on sony KDF-42WE655,
SD Tech,
With your kind permission if I may provide info...
3 times red light blinking shows that lamp cover has not been fixed in its place securely after lamp replacement.
Make sure lamp cover, its the first plastic cover that was removed to replace lamp, is back in its position properly then turn On tv.
This plastic lamp cover engages safety micro switch inside tv cabinet.
Posted on Aug 20, 2010
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Power light flashes green once then amber 7 times
change/clean manually the main roller because it observe ink.
Jun 23, 2010 | Canon i950 InkJet Photo Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Red light flashes & times
7 blink error is 8.6 volt error usually tied to y main board. would advise to disconnect y main from power supply and verify vs voltage. if vs is present replace y main and general protocol is to replace y upper and lower buffers as well as they complete circuit
Aug 10, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sony KDF-37H1000 37" HDTV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
