Question about Sanyo Televison & Video
Sanyo Dp53360 service manual
Need service manual for internal schematics Tv will come on, led blinks twice w/ message please wait then immediately shuts off need please help and service manual for internal schematics. Tv only 1.2yrs old.
  • complex22222 Feb 12, 2012
    Yes. I did place the wrong model#. Thanks for your correction and reply. Fortunately, I am looking for the internal schematics within a service manual rather than a user or owner manual within your suggestion. The owner manual only addresses external connection eschematics not internal structure schematics. Correct Model# DP55360. You are definitely right about that!
  • 37 Answers
It was a little harder to find since you gave the wrong model number :)
Model number is DP55360. Here is the user's manual: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20(348A-)-38838316.pdf
Internet User's Guide: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20internet%20guide(358--)-34613941.pdf
Posted on Feb 12, 2012
Testimonial: "This solution was helpful. 1 Source: Phillips 51in tv rear projection power button blinking green Was this solution helpful? Yes "
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Phillips 51in tv rear projection power button blinking green
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
I need the steps to program the urc4021 remote, as well as the code for the sanyo tv
To program the One-For-All URC4021, first turn on the TV manually (or with the original remote). Press the TV button on the URC4021 once. Then press and hold the Set button until the LED blinks twice. Now you can enter a code directly and test it. For Sanyo TVs, the only programmed code is 0154 . If the LED blinks twice, press Power to attempt to turn off the TV. If that works, you can turn the TV on again and test if the other buttons on the remote work with your TV. If the LED doesn't blink twice, repeat the steps from pressing and holding Set. (If you wait too long before entering the code, the remote will leave the programming mode.)
The URC4021 has a code search mode. Press and hold Set until the LED blinks twice, then press 9 9 1 . If the LED blinks twice again, alternate between pressing the Power and TV buttons until the TV turns off. Then press Set to lock in that code and test the remote again.
I hope this helps.
(Note: if your TV is newer than the remote or released within 6 months of the remote being programmed, this code may not work. The URC4021 documentation gives March, 2004 as the copyright date. That suggests that the codes may not work with devices built in 2004 or later.)
Sep 29, 2015 | Sanyo Televison & Video
What is the code for a sanyo tv and how do I program it
If your TV is older than the URC-4220, the code should be 0154. (The universal remote generally can only control devices that were released about 6 months or more before the remote was programmed.)
To program the remote, turn on the TV manually. Then press the TV button on the remote once. Press and hold Set until the LED blinks twice. Release the Set button at that point. Enter 0154, check if the LED blinks twice again. If the LED blinked properly, point the remote at the TV and press Power. If the TV turns off, this is the correct code. If you take too long between steps, the remote may leave the setting mode. If the LED didn't blink, start over from pressing the TV button on the remote.
The manual for the One-for-All URC-4220 remote is available here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/11828/~/programming-and-operating-the-oneforall-urc4220-universal-remote-control . Scroll past the directions for using and programming the remote to the link to the Owner's Manual. The list of codes starts at page 36.
I hope this helps.
CIndy Wells
Feb 10, 2015 | One For All URC4220 Remote Control
I need code for a sanyo tv.
If your device does not respond to the remote control
after trying all codes listed for your brand, or if your
brand is not listed at all, try searching for your code.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the the TV and
slowly alternate between pressing POWER
and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control
will send IR codes from its library to the selected
device, starting with the most popular code first.
5. To lock in the code, press and release SET.
6. To search for the codes of your other
devices, repeat steps 1 through 5, but
substitute the appropriate device key for
the device you are searching for.
or you download the manual here
May 15, 2010 | One For All URC-6131 Remote Control
I need the code to a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the four-digit code 0154.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 04, 2009 | One For All URC-3021 Remote Control
Need the code for a sanyo tv
1) Turn on your TV.
I hope that helps.
Nov 30, 2009 | One For All URC-3021 Remote Control
Need code for programing
Manual is available at One For All here
http://www.oneforall.com/uploads/support/6c8b036cd3ba3806d00e5a1c57409ef0.pdf
To set up remote
1. Turn on TV.
2. On remote press TV key once.
3. Press and hold Set button until LED blinks twice
4. Enter first 4 digit code for your TV manufacturer from the manual above (P.18). LED blinks twice if code has been entered correctly, if not go to 2.
5. Press Power and the TV should switch off, if the TV doesn't switch off go to step 2 and repeat with next code for your brand until TV does turn off.
Searching for code
1. Perform steps 1 to 3 as above.
2. Enter the code 991. LED will blink twice.
3. Press Power button.
4. If TV turns off
Press Set - LED will blink twice.
If TV doesn't turn off
Press TV button and go to repeat step 3 and 4, until TV does turn off.
Check a code.
If you've used the search function you might want to know what the code is to do this...
1. Perform steps 1 to 3 from set up remote at the top.
2. Enter code 990, LED will blink twice.
3. For the first code press 1. Wait 3 seconds and count the times the LED blinks, that is your first digit, if the LED doesn't blink that is 0.
4. Repeat step 3 for remainder codes, pressing 2 for second digit, 3 for third and 4 for fourth.
It doesn't state in the manual how to get out of this mode but normally it is either leave the remote alone for 5 minutes, or press any other button other than 1 to 4.
Nov 10, 2009 | Televison & Video
Urc-3021Boo one for all set up and codes for a sanyo tv
1) Turn on your TV.
4) Enter the code 0154.
If it does not turn off, try the auto-search function.
To search for a code for your TV:
  2. Press and hold SET until the LED blinks twice, then release SET.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
Blank screen two led lights blink twice and then one led light blinks once.
The led blinking is an error code from the internal processor - defining the nature/area of the TV's internal problem.
A service manual (if available) will de-cipher the codes.
The tv will probably need to be repaired by a service technician.
Oct 07, 2009 | Sharp LC37SB24U 37 in. LCD TV
I need the code for a phillips universal remote model CL034 to go with a durabrand tv?
Probably not going to find a specific code since durabrand is a walmart branded tv, your best bet is to try the automatic mode of your remote, or try different brands of tv, starting with sharp/sanyo/sony as those brands are ones that walmart sells most.
Sep 23, 2009 | Philips Universal PH301S Remote Control
Led light will not light
dvd citizen i need a code please
Jan 08, 2008 | One For All URC4220 Remote Control
Televison & Video Logo
539 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
